Fixing Ethernetport LWAPP AP's
How can I fix the ethernet port settings (speed, duplex) on a LWAPP AP 1230 or 1240?
Pascal
Re: Fixing Ethernetport LWAPP AP's
The LWAPP is configured by a controller that doesn't have anywhere to change speed and duplex settings on the AP's (at least not from what I've seen). There is a known issue with AP's connected to 4500 series switches (don't have the article). I've found that if you set your switchport to auto auto the AP negotiates to 100/full. If the port is static 100/full the AP will go to 100/half for some reason.
Could you possibly find that article about the issue with Ap's connecting to 4500's? I'm having that problem with 1232's converted to LWAPP and connecting them to a 4500 with 10/100/1000 blades.
Bronze
After enter command "debug lwapp console cli", you can go to AP config mode and configure it like configuring an IOS AP.
146
