12-23-2013 01:43 PM - edited 07-04-2021 11:50 PM
Good Afternoon,
I was hoping someone might be able to shed some light on an issue we are having. When we have our WLAN set to Central Authentication the clients stay connected with much longer UP times than when we have it set to Local AUTH. Our authentication server is the same for both modes. We receieve the following error right before the client reassociates:
apfReceiveTask: Dec 23 16:30:39.330: #LWAPP-3-INVALID_AID2: spam_api.c:1357 Association identifier 3 for client 00:db:df:19:91:46 is already in use by 00:db:df:19:91:46
Also another issue, which might be client related. When we connect to the AP's with Local Auth the client reports incomplete infromation:
Security Information
Quality Of Service Properties:
Does this essentially mean they are no working in Local Auth Mode? It is important to know if the clients connected to Flex AP's are using WMM.
Thoughts?
12-24-2013 01:15 PM
Does the client disconnect while stationary or during roaming?
What is the code running on this wlc?
Please share,
config paging disable
show wlan
If you can share this debug while capturing atleast one or two drop events.
debug client
debug dot11 management enable
Sahil
12-27-2013 05:12 AM
Please share,
show wlan
debug client
Sahil
The client is stationary not roaming.
The controller is on 7.4.110.0
I will try to get you this information as soon as possible. Thanks for the response.
12-26-2013 07:50 AM
use latest 7.4 code, if not already. AID leak bugs were fixed on it.
regards to client detail, did you check, if client was on run state.
even with central switching and centrsl auth, sometimes i have seen eap type 0 for peap when client is on run state, however other fields were update.
12-27-2013 05:15 AM
I am on the 7.4.110 code. I see that they just released 7.4.121.0 but i dont think we'll jump on that right away.
The cleints are in RUN state but it still is strange that they always show WMM state Disabled. Do you think WMM is still running\working and it is just a cosmetic issue?
12-27-2013 09:05 AM
The client might not support WMM, which there are clients that do (Cisco phones) and clients that don't support WMM.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
12-27-2013 11:28 AM
Scott
@Scott,
Thanks for the response, however the strange this I know both clients i have been reviewing are both WMM capable. I am testing with an intel based CCXv4 certified WLAn client and a Spectralink 8440 VoWLAN phone. When I have the WLAN set for local AUTH\Local switch i dont see the EAP params and they show WMM disabled. When i switch said WLAN to Central Auth\Local switch i see the EAP params and they show the WMM enabled and U-APSD shows active.
12-27-2013 11:53 AM
There is information from the client that doesn't get passed to the WLC since the mode is local switching. So when you are centrally switching and then locally switching, you will see various difference when looking at the client.
12-27-2013 11:57 AM
This has nothing to do with Central Switching but rather Authentication. Did you mean Central V Local Auth?
I see this information when it uses Central Auth, is that because all the AUTH requests are going to the controller passing this information?
I just need to know that WMM is actually working in Flex Connect mode or if it is a bug i suppose.
I am probably going to ping Cisco's ears on this i was just hoping someone in the forum would have experienced this and had ruled out that its a problem
Unfortunately i dont have any air magnent or AIR PCAP cards to see if the phone or client is acutally using WMM.
12-27-2013 12:16 PM
You have two Cisco engineers who have posted here. You either wait for them to respond or you call TAC. I don't think you will see wmm info when locally switching.
12-27-2013 12:23 PM
You do see WMM information when using local switching just not local Auth. I will try to get some more information for the engineers on this post.
Thanks again.
12-27-2013 12:25 PM
#Check the trying client is wmm capable or not. If capable check the respective client doc to enable the same.
#once wmm enabled on the client or it is enabled by default for the given manufacturer, connect the client on centrally switched wlan, verify wmm status - If it showing wmm enabled then try connecting to the wlan in question and verify.
#There is an negative test to verify, if client is wmm or not. On centrally switched wlan set wmm to required, the non wmm client will not connect to it.
#When local switching is enabled, WLC doesn't snoop the client info, however AP can forward the client info to WLC, there is no doc that says what client info will get forwarded other than its IP via enabling learn client ip.
12-27-2013 12:31 PM
Saravanan,
Good idea for testing to verify that WMM is functioning as expected in Local Auth mode. I will enable WMM required on the WLAN and see if that allows the device to still connect.
As far as the Local Auth\Central Auth client UPTIME problem. I will to get valid logs. I know right now that a single client connecting to same Auth Servers via Central and Local Auth show different UPTIMES and this is proven to be the case for our other environments. I see hours or more of client uptime when using Central Auth and see much smaller uptimes with Local AUTH in use. I dont know if it is causing a client issue but just seems to be strange and causes some confusion when troubleshooting wireless issues.
12-31-2013 08:04 AM
Making a come back on this, here is what i have.
CSCul57266 Show client detail on WLC is inaccurate compared to the Flexconnect AP
Note# Specific case: Local Auth is enabled.
Workaround: Check "show capwap reap association" reflecting true stats.
Now for the stated/suspected client drops/reassociations, we would need logs.
This should validate if it truly is a drop issue, or just the incorrect stats displayed for those.
Sahil
01-02-2014 10:15 AM
Sahil
I checked the CAPWAP reap association on the AP and the clients infact appear to be dropping only when using Local Authentication in FLEX mode.
what debug logs should i run to provide the information you need?
