04-28-2014 06:24 AM - edited 07-05-2021 12:44 AM
Hello.
A client of mine wants to offer WiFi connectivity in several strategic points in our city (no authentication required). The only requirement is a redirect to their home page when a user opens a web browser; is this possible to be done with a WLC?
Also, are there any issue in having APs behind NAT? From the networking point of view I believe I need a static NAT for the WLC but APs can use PAT to reach WLC, am I correct or are there any issues on this subject?
Joao.
Solved! Go to Solution.
04-28-2014 08:40 AM
In the webauth configuration, there is an option there to set the redirect page. So after the user clicks accept on the T&C they are pushed to the page you define there.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/69340-web-auth-config.html
04-28-2014 07:21 AM
You should be able to do this with the WLC. For the redirect to the city page, you would setup a splash page with your T&C, and you can specify a redirect page there, pretty standard.
For the AP, yes they can be behind a NAT, just make sure that UDP 5246/5247 are allowed through your NAT device so the AP can join.
HTH,
Steve
04-28-2014 08:35 AM
Hello Steve.
I went to read something about splash pages and I do not see how I can do this without the use of authentication and ACS.
Can you explain how would traffic be redirected at each site everytime user connects to WiFi?
João.
04-28-2014 08:40 AM
04-29-2014 03:25 AM
Hello Steve.
Just one final question. For this to work I assume that the WLAN must not be configured for local switching; otherwise, the WLC is not able to intercept webtraffic. Am I correct on this assumption?
João.
P.S. - I know that the question might sound stupid but I do not have a WLC and APs to test the client requirements.
04-29-2014 05:39 AM
No, webauth redirect should still work with FlexConnect.
Steve
