Community Member
Getting Started with Wireless: Wireless configuration on 877W router - STUC
Just letting you know that I've already posted an identical post under "Getting Started with Wireless" but don't feel that I'm getting any attention so I made another post. Thank you.
Hi all
I have a Cisco 877W router running IOS v 12.4(15)T3. Have been trying to configure wireless to run WPA-PSK and is stuck at the final stage. Spent a lot of time configuring the router using CLI but ended up using the Web GUI interface. I was able to configure the wireless settings (I think) but failed when connecting to the router from WinXP-SP2 and was wondering if you have any suggestion for me. I've ran the following debugs on the router:
VNRouter#sho debug
DHCP server event debugging is on.
dot11:
802.1X module WPA/WPA-PSK/CCKM key management debugging is on
dot11 Syslog debugging is on
Below is the error message when connecting wirelessly
*Mar 4 18:46:25.655: *** Not encrypted dot1x packet from 001b.771a.dbad has been discarded
VNRouter#
*Mar 4 18:46:25.659: %DOT11-6-ASSOC: Interface Dot11Radio0, Station VNRouter 001b.771a.dbad Associated SSID[VN-WiLess1] AUTH_TYPE[OPEN] KEY_MGMT[WPA PSK]
VNRouter#
*Mar 4 18:47:25.571: *** Not encrypted dot1x packet from 001b.771a.dbad has been discarded
*Mar 4 18:47:25.575: *** Not encrypted dot1x packet from 001b.771a.dbad has been discarded
*Mar 4 18:47:25.579: *** Not encrypted dot1x packet from 001b.771a.dbad has been discarded.
I've created two VLANs (and tied these two vlans to 2 separate SSID) on this router for a reason and so far has not been able to connect to any of them (SSID). I've also attached the config so you can have a look. Thanks in advance for your help.
1 REPLY
Silver
Re: Getting Started with Wireless: Wireless configuration on 877
The configuration looks fine. In most cases, the connectivity issues with WPA-PSK is due to the mismatch in PSK on the Client and the AP. Try re-entering the PSK key on both the router and the client and check if you are seeing any issues.
239
