09-02-2013 02:54 AM - edited 07-04-2021 12:44 AM
I upgraded a customer 5508 to 7.5.102.0 the other day and now can't access the GUI using Google Chrome. I get a page saying "SSL connection error".
It works fine with Internet Explorer and Firefox.
The final Wireshark packet in the Chrome trace says "Handshake Failure".
Have upgraded Chrome and tried with different laptops with the same result.
I have also upgraded our lab controller (also a 5508) and that's the same.
Anyone else seeing this?
Solved! Go to Solution.
09-05-2013 05:49 PM
Hi Guys,
This is being investigated.
Chrome 29 adds TLS 1.2 support, and WLC is selecting a crypto suite over TLS 1.0 that apparently is breaking client.
Try this workaround for now.
config network secureweb cipher-option rc4-preference enable
Save and reboot required.
Sahil
09-02-2013 06:25 AM
Yeah.... its when I upgraded my Google Chrome! I had v7.5 running fine until I upgraded my browser. If you google it, other have ran into this issue in general. I think that Chrome has corrupted information that has to be removed, but where to remove it is the questions.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
09-05-2013 09:21 AM
Any news about this issue?
We are facing exactly the same problem.
Cheers.
09-05-2013 12:08 PM
I have the same problem too. Additionally Guest Wireless portal also not working for Google Chrome clients after upgraded to 7.5.102.0. Looking for permenant fix without ask to change the browser (in guest scenario not possible to do this & most of android devices comes with chrome as default browser)
Rasika
09-05-2013 05:49 PM
Hi Guys,
Sahil
09-05-2013 05:59 PM
Sahil,
That worked!
Scott
08-13-2019 09:43 AM
09-05-2013 07:54 PM
Hi Sahil,
Thank you very much for quik response & give a workable solution. I have applied this and guest wireless issue with chorme has vanished..
Thanks again & +5 for you
Rasika
09-05-2013 08:02 PM
Hello guys!
That worked for me too!!
Many thanks Sahil!
09-05-2013 08:27 PM
Sahil
+5
10-24-2013 02:01 AM
Great, I will also try this. But if it does not work or it is fixed in a later version, how do I revert this setting?
With:
config network secureweb cipher-option rc4-preference disable
11-18-2013 05:23 AM
Thanks Sahil for sharing this useful information with community users 5+ :-).
This document was generated from the following discussion
Vinay Sharma
Community Manager
09-06-2013 01:32 AM
Works for me too. Thanks for the info!
10-29-2013 03:36 PM
Well done Thanks for the Fix
