Gold
GPRS and PIX
Has anyone implemented a GPRS solution using a PIX? If so, did you encounter any problems?
Basically I'm looking into implementing a GPRS solution for a customer, i.e. I'll allow GPRS traffic out (smtp only) by using ACL on the inside interface via port 3100. All I'm looking for is if anyone has done this before and encountered any problems, if so, what sort of problems?
Thanks in advance.
Re: GPRS and PIX
Unless you plan on putting the PIX between the GGSN and SGSN then it will just be a standard IP packet and will be treated by the PIX like any other IP packet from any sort of access media
Gold
Re: GPRS and PIX
David - Thanks for your input.
148
