Guest access on 877W- Consent Feature
After reading a little on possibilities for implementing a multi-site Guest Wireless Access solution, it seems to involve alot of expensive gear.
Is it possible to implement same on multiple 877W's, for example, using the Consent Feature, available in 12.4T. See link:
http://www.cisco.com/en/US/customer/products/ps6441/products_feature_guide09186a00808411e8.html#wp1053144
If so, could authentication be forwarded to a central auth server, like RADIUS, for example?
Thanks, Mark
1 REPLY
Silver
Re: Guest access on 877W- Consent Feature
I don't think this feature can be configured on the 877 wireless router. You can configure multiple VLANs on the 877 router and have your guest and internal WLANs on those VLANs.
You will find information on configuring Wireless on 877 at http://cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html
163
