01-28-2014 02:35 PM - edited 07-05-2021 12:03 AM
Could someone please tell me if the WLC support this senario. Guest user associates to an open SSID, get's redirected to captive portal page where they are prompt to enter their email address, and then accpet AUP, and allowed Internet Access? Can this be done on either the WLC itself or with ISE? If not, what's the closest work flow that can be done?
,Angel
01-28-2014 03:07 PM
This can be done on the WLC, but the email address isn't really verified and also the email can be collected from the logs only. Here is a screen shot of where you can configure the email from the WLAN
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-28-2014 03:09 PM
Here is a link also:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080bf7d89.shtml#passthrough
ISE can give you a better work flow, but its not cheap. With ISE you can have a sponsor or even self registration, but with the WLC itself, your limited to passthrough, passthrough with email or webauth.
Scott
01-28-2014 03:23 PM
Thanks Scott, I'll have to try this.
,Angel
01-28-2014 03:24 PM
No problem.... should be pretty straight forward.
Scott
