guest auth. over flexconnect and dhcp server on WLC in centrall site.
Will this be working?
I have a flex AP on branch where guest users should authenticate at WLC in central site and get dhcp adress also from WLC..
Is this possible?
regards
Chris
13 Replies 13
ermkgupta
Yes very well possible.
Sent from Cisco Technical Support Android App
okay
how to do this? in my case it does not work, client does not get an IP from WLC...
Do i need sort of a dummy interface for this flexconnect WLAN?
regards
Is the client traffic backhauled to the WLC? That's the only way that would work.
Normally the client will get DHCP from the local subnet if you are looking to keep the guest local.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
okay
I have my DHCP on the WLC, but i have 2 scopes on the WLC, one for guest users at Central site, and one scope for the guest users at the branch site..
I have configured a "dummy" interface with IP Adresses from the branch guest site and mapped this to the WLAN ID but it does not changed anything..
So you are using FlexConnect AP's and you guest SSID is locally switched and centrally switched and you want the WLC to hand out DHCP address to guest that are locally switched and centrally switched. The central switched works and the locally switched doesn't?
Make sure the interface has the WLC management IP address as the primary DHCP server. If both DHCP scopes are not working, then make sure that DHCP proxy is also enabled.
-Scott
You can still "local switch" the client data, yet "central process DHCP".  On the WLAN you will want to select the option i the advanced tab to utilize "Central DHCP Processing"
The AP will forward the DHCP traffic back up to the WLC and once it passes through the DHCP_REQD state and the address is learned, the client will move on to locally switching its data traffic.
"When you enable this feature, the DHCP packets received from AP are  centrally switched to the controller and then forwarded to the  corresponding VLAN based on the AP and the SSID"
In this case, the WLC will deliver the DHCP via bridged mode or DHCP proxy utilizing the mapped interface to the said Flex WLAN.  You will want to ensure that the client obtains a usable address that will correspond with the network the client will be switching on locally at that site.
Ali Aqrabawi
hi.
can you share show wlan
Cisco Controller) >show wlan 4
WLAN Identifier.................................. 4
Profile Name..................................... guest-branch
Network Name (SSID).............................. guest-branch
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... xxxx
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ guest-branch
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11b and 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
--More-- or (q)uit
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Enabled
        IPv4 ACL........................................ Unconfigured
        IPv6 ACL........................................ Unconfigured
        Web-Auth Flex ACL............................... Unconfigured
        Web Authentication server precedence:
        1............................................... local
        2............................................... radius
        3............................................... ldap
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
--More-- or (q)uit
   FlexConnect Local Switching................... Enabled
   flexconnect Central Dhcp Flag................. Enabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
--More-- or (q)uit
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
(Cisco Controller) >
--disable the local switching on the WLAN,
--configure the DHCP for guest-branch interface, either (local DHCP scope on the WLC with enabling the DHCP proxy and the DHCP server ip on the interface would be the mgmt interface of the WLC) or disable the DHCP proxy with external DHCP server.
--if you had already do the above and the clients still not getting ip address , share >debug client
Ali Aqrabawi
can you please confirm this:
you want the client to get ip address from the WLC ,
but do you want the clients to access only the local network ?
or the clients should access the local and central networks ?
​1. yes client ip from WLC at central site
​2. client access both networks, but more local applications.
​networks are connected via vpn and checkpoint firewalls
so then you want the split tunnel feature ,
you can use the link below to help you configuring this :
http://www.cisco.com/c/en/us/support/docs/wireless/flex-7500-series-wireless-controllers/112973-flex7500-wbc-guide-00.html#split
this feature allow you to create flexconnect ACL and map this ACL with WLAN on specific AP ,
if the packet is permit according the ACL then this packet will switched localy , if not the packet will be forwarded centrally to the WLC.
i hope this will be useful
thank you
herve.leon
Hi Christian,
It's a long time this discussion has been opened.
Did you manage to get an IP address from the  Local DHCP server (WLC) for guest users on branch ?
I'll be interested by your feedback
Hervé
