Guest network password not working after changed
I am running a single controller servicing both guest and corp WLAN's.  The password was changed on the guest account and users are not able to authenticate with the PSK.  The password for the "local net users" was changed by mistake prior to changing the Guest network password.
do you use WCS / NCS or the simplified guestnet access from the WLC itself?
I went through the controller.  Seleceted the guest WLAN, Layer2 security tab, changed the PSK.
that's the right way.
Didn't you type of copy the PSK? Sometimes you'll get a white space after...
Did you use strange characters. Try a simple PSK to be sure.
On what WLC version you're running now?
I typed the password, did not copy it from anywhere.  No strange characters, leters and numbers only.  Current version is
6.0.182.0
To change a local network user password, you can also use the config netuser password command.
UPDATE:
I was able to connect just needed to reboot my PC, howerver I am unable to connect my IPhone to the guest network whch I was able to do before.
Hall of Fame Super Silver
Create a new username and password for a test guest user and try to use that and see if it works.  Your doing webauth correct?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
No web auth just PSK.
Well something isn't right then... if you changed the PSK on the WLC and then your tried to use your iphone to connect and it doesn't, then you need to forget the wireless network on the phone and create it again.  Also you need to make sure that the WLAN is either set to wpa-tkip or wpa2-aes, not both and not a mix of either one.
Scott
-Scott
Currenetly set to WPA2 AES, see bwlow.
Layer 2 Security 7
MAC Filtering
WPA+WPA2 Parameters
WPA Policy
WPA EncryptionAES       TKIP
WPA2 Policy
WPA2 EncryptionAES       TKIP
Auth Key Mgmt
PSK Format
No... it is set to wpa-aes and wpa2-aes.... that is wrong adn thats is why your having issue with tablets... you need to use either wpa-tkip only or wpa-aes only.
Scott
-Scott
In the drop down the only option for WPA is to use WPA+WPA2.  What should i choose in this case?
You keep that configuration, but you need to uncheck WPA Policy
Scott
-Scott
Here is a screen shot of mine but I'm running v7.5
Scott
-Scott
197
