H-REAP clients disconnect each 10 minutes
Hello!
I'm experiencing a problem with H-REAP users.
I have set up a WLC 4402 and WLAN with WPA2+DOT1X. Controller authorizes clients via RADIUS.
H-REAP access points (1131AG) are connected through a 2Mbits link and local switching is enabled for the WLAN.
The problem is that clients lost connection with the WLAN and recconect againg shortly. All tcp sessions are dropped at that moment.
It is seen from a debug that disconnects occur because of pmk chache expires and client needs to reauthenticate.
As far as I can see pmk cache expiration time isn't controlled from a config. I believe that such behaviour is wrong (i mean routinely disconnections).
Does anybody know why it happens and how should I set up a H-REAP mode to have permanent reliable connection to the WLAN?
1 REPLY
Silver
Re: H-REAP clients disconnect each 10 minutes
The PMK cache is related to the session timeout value in the WLAN. Default setting is 1800 seconds, which should be about 30 minutes. This is only the timeout for the session key, and not the authentication. If the client is needing to reauthenticate frequently, I would look at the time outs in your AAA server and see what they are set too.
278
