07-08-2008 12:59 PM - edited 07-03-2021 04:08 PM
The documentation is a little fuzzy on what is supported. Does anyone know if H-REAP will work with the 1131G Access Point?
07-08-2008 01:03 PM
Yes it is supported :)
H-REAP is only supported on the 1130AG, 1240AG and 1250 access points and on the Cisco 2000, 2100 and 4400 Series Unified Controllers, the Catalyst 3750G Integrated Wireless LAN Controller Switch, the Cisco WiSM, and the Controller Network Module for Integrated Services Routers.
http://www.cisco.com/en/US/products/ps6521/products_tech_note09186a0080736123.shtml#req
11-07-2008 02:14 AM
I have access point model
AIR-AP1231G-E-K9 and when I converted to LAP it didn't support H-reap:-(
How can one be sure that access points will support H-reap or not?
11-07-2008 04:26 AM
forget my last post, I just found a doc saying that 1231AG DOES NOT SUPPORT H-REAP
11-07-2008 04:27 AM
That model is not.
H-REAP is supported only on the 1130AG, 1240AG, 1250, and AP801 access points and on the 2100 and 4400 series controllers, the Catalyst 3750G Integrated Wireless LAN Controller Switch, the Cisco Wireless Services Module (WiSM), and the Controller Network Module for Integrated Services Routers
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008081103d.shtml
11-07-2008 08:19 AM
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc3b8.shtml
Under background information it states that only 1131, 1242, and 1250 APs support this feature.
