H-REAP supported APs
I have one and quick question. I am planning a new installation and have tested the functionality with 1242 APs. For the real project I doubt whether it is supported for the new 1141 APs. The only statement I managed to find is that 1130, 1240 and 1250 Series APs that support H-REAP functionality.
I would like to ask if somebody can tell me which Lightweight AP are working with H-REAP. It is important to be sure...
Georgi
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: H-REAP supported APs
Hi Georgi,
Yes, H-REAP is supported on the 1140 series of AP's. Some of the older docs have not been updated to reflect this change, but this info is included in newer versions;
Hybrid REAP is supported only on the 1130AG, **1140, 1240AG, 1250, and AP801 access points and on the 5500, 4400, and 2100 series controllers.
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60hreap.html
Hope this helps!
Rob
Hall of Fame Super Silver
Georgi,
I have used all the models you have listed in H-REAP. They all work... the only thing is that the 1142 requires the 5.2 or higher code.
-Scott
Hi Georgi,
Hope this helps!
Rob
Yes it helps. That's what I needed...
I appears that I haven't searched enough... But it is easier to ask :)
Thanks, that's not the first time you help me...
458
