Hardware issue with AIR-AP1252AG-N-K9
We have a client that has a large number of AIR-AP1252AG-N-K9 installed in the network with power injectors. We have seen a about 48% failure rate of AP's failing with all 3 red lights on the unit. Once I get the AP in the lab I'm unable to get any response from the console, therefore unable to troubleshoot..
Is any one seening the same issue?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Have you tried checking your cables?
I have >100 1250 in my network and some are using injectors.  So far I have 3 failed injectors and about <10 failed unit and any other issues I had has something to do with my cables failing TDR tests.
If you have Cisco switches, what are their EXACT models?
Thanks for you feed back.
I'll get the cablers to double check the cabling, targetting a number of AP's.
Will let you know how I go.
668
