10-21-2013 01:21 PM - edited 07-04-2021 01:07 AM
Has any used the 3602e as a bridgeing only between two networks? Controller 2504 version 7.4.100 I can't ping anything on either side of the network, but I can ping from the controller to each AP.I have two 1552 setup the same way with no issues.Has anyone seen this before?
Thanks!
Solved! Go to Solution.
10-22-2013 06:29 AM
In the case of 3602e as bridge link, and you bet the config is a working one, then I would suggest check the antennae if they are properly aligned, if you are using proper one, a higher gain one would be a needed in case of 3602e I guess so.
10-22-2013 10:36 AM
I'm guessing your using 3602e's as a RAP and MAP with Ethernet bridging on the MAP? This works as I have tested this out at my he lab with a 2504 and 3602e and 3602i. Now depending on what's connected to the Ethernet in the MAP, that could be the issue. I only connected a single device to test and since you said you are trying to bridge two networks, it seems like a true bridge is really what you need.
10-22-2013 11:25 AM
There have been issues with Ethernet bridging with indoor AP's with v7.2 and v7.3, but was fixed in v7.4. If your using native vlan or access port then your Ethernet bridging will also be on the same vlan as the AP. This is the same for mesh and indoor mesh AP. Why it's not working, I don't know. If you connect a laptop to the MAP's Ethernet port, does it function properly?
10-30-2013 01:22 AM
Hi Limuel,
Any progress with the testing?
I have a customer that has the same setup with version 7.5.102. He also has an issue in setting up the MAP/RAP bridge.
Thanks.
Kind regards,
Thomas
10-30-2013 11:29 AM
I have juste tested this on a 2504 with v7.5 and 3602e and was able to connect a laptop to the ethernet port and obtain an ip address and do have connectivity.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
10-30-2013 12:06 PM
So let me ask... If you kept dhcp on the MAP, does it work?
10-30-2013 12:16 PM
Well... Just put a static on the MAP, waited for it to join the WLC and then connected my MacBook to the Ethernet and it's working fine.
10-30-2013 12:18 PM
Yes, but it's okay as I tried it. Still works fine for me. My RAP is a 3602i and my MAP is a 3602e.
10-30-2013 12:53 PM
What I'm doing is connecting a laptop directly to the 3602e gigabit ethernet port.
Scott
10-22-2013 06:29 AM
10-22-2013 11:11 AM
Saurav,
Thanks for the response. Its in a test lab about 70 ft away from the other 3602e, I have moved it closer same issue I am using Omni antennas.
10-22-2013 10:36 AM
10-22-2013 11:20 AM
Scott,
Thanks for the response. Yes, One is a RAP and the other is a MAP. I will have to check I think I checked the brideging box on both AP's.The RAP and the MAP are connected to a switch that only allows native traffic to go through it. Its a propiertiery switch my company make,that doesn't allow vlans to be set on it, only native traffic. The kicker is,as I mentioned above, the 1552 is setup the same way, its the primary unit the 3602e is the secondary unit.
10-22-2013 11:25 AM
10-22-2013 11:33 AM
When you tested this what controller version did you use? Yes, when I connect a laptop everything is fine, its just that I can't ping any other device on the other side of the bridgeing network. No other devices are on the network besides the switches AP's and the controller.
10-30-2013 11:13 AM
Thomas,
I have not had any luck with getting this to work in RAP/MAP bridging mode.
10-30-2013 01:22 AM
Hi Limuel,
Thanks.
Kind regards,
Thomas
10-30-2013 11:15 AM
Thomas,
I posted thr reply in the wrong area. No, I haven't had any luck with getting this to work in RAP/MAP bridging mode.
10-30-2013 11:29 AM
Scott
10-30-2013 11:58 AM
Scott,
Here is my test the smart switch only allows one vlan, so everything is on one vlan. Once my AP's got an address from my controller, I set them up with static addresses can you test this? After that see if you can ping anything on the MAP side.
Thanks!
10-30-2013 12:06 PM
10-30-2013 12:13 PM
Do you mean instead of giving the MAP access point a static address?
10-30-2013 12:18 PM
