02-26-2009 12:24 AM - edited 07-03-2021 05:14 PM
Hi can anyone help me decode what the problem is with this client. Error says 802.1x is required when I'm using WPA/PSK authentication?
I get these error all the time
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :Controller association request message received.
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :Association request received from a client has an invalid RSN IE.(One reason could be mismatch in WPA2 algorithm)
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :Received reassociation request from client.
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :The wlan to which client is connecting requires 802 1x authentication.
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :Client moved to associated state successfully.
Time :02/26/2009 09:06:19 CET Severity :ERROR Controller IP :x.x.x.x Message :802.1x authentication message received, static dynamic wep supported.
Time :02/26/2009 09:06:21 CET Severity :INFO Controller IP :x.x.x.x Message :802.1x authentication was completed successfully.
Time :02/26/2009 09:06:21 CET Severity :INFO Controller IP :x.x.x.x Message :Client has got IP address, no L3 authentication required.
Time :02/26/2009 09:06:30 CET Severity :INFO Controller IP :x.x.x.x Message :Controller association request message received.
Time :02/26/2009 09:06:30 CET Severity :ERROR Controller IP :x.x.x.x Message :Current load on the radio of this AP is exceeded hence ignoring the request from this client.
03-23-2009 06:53 AM
Depending on code it should be down below the 802.1x key management box.
03-26-2009 11:34 PM
I've found the info about this bug: CSCsx59156. Sounds something like the problem we have, but we didnt use Wlan Template, we configured with Configure/Controllers in WCS. But the effect may be the same?
