Community Member
help dhcp wlc urgent
Hello guys, need your advice
My AP get IP from 6509, but client cannot get dhcp from my dhcp pool for client, what is the reason?
i have 3750g switch with integrated WLC, i connect it to 6509
I did all configs yesterday here is outputs
WLC
Interface Name                  Port Vlan Id  IP Address      Type    Ap Mgr Guest
ap-manager                      LAG  10      172.16.10.100  Static  Yes    No
globus                          LAG  20      172.16.20.254  Dynamic No    No
management                      LAG  10      172.16.10.99    Static  No    No
service-port                    N/A  N/A      0.0.0.0        Static  No    No
virtual                          N/A  N/A      4.4.4.4        Static  No    No
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 5.1.151.0
RTOS Version..................................... Linux-2.6.10_mvl401
Bootloader Version............................... 4.0.217.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_7e:a2:47
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.747
IP Address....................................... 172.16.10.99
System Up Time................................... 0 days 0 hrs 46 mins 22 secs
System Timezone Location.........................
Current Boot License Level.......................
Next Boot License Level..........................
Configured Country............................... SE  - Sweden
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +35 C
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 0
AP side
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
AP0021.a0d5.ec9c uptime is 10 minutes
System image file is "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"
cisco AIR-LAP1131AG-E-K9  (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1305Q0G6
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:21:A0:D5:EC:9C
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC12521ACW
Top Assembly Part Number            : 800-29144-03
Top Assembly Serial Number          : FCZ1305Q0G6
Top Revision Number                  : A0
Product/Model Number                : AIR-LAP1131AG-E-K9
Configuration register is 0xF
Burned-in MAC Address............................ 00:24:14:7E:A2:40
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 50
6509 side dhcp config
ip dhcp pool AP
  network 172.16.100.0 255.255.255.0
  default-router 172.16.100.1
  option 60 ascii "Cisco AP c1130"
  option 43 hex f108.ac01.0a63
ip dhcp pool wireless_users
  network 172.16.20.0 255.255.255.0
  default-router 172.16.20.1
Everyone's tags (1)
Community Member
Check vlan cfg for first, if is ok, I had similar problem in one our site, I delete the scope and create again and now work properly,
Kamran:
- Your WLC version is very old and not even recommended. Please upgrade to a newer one (7.0.230.0 is latest. check upgrade path before upgrade).
- Do you have a Layer 3 interface on your switch on the range 172.16.20.0? if yes, on what is the vlan interface config?
Amjad
Rating useful replies is more useful than saying "Thank you"
Community Member
Guys I made it to connect with ap only using comand on ap
lwapp controller ip address /ip/
and it works fine, but i need to make ap join automatic
any ideas?
Kamran:
You said that the AP joins successfully but the client's do no get an IP.
Now you are saying the problem was that the AP was not joining WLC at the first place!!
You need to describe the problem correctly for us to be able to help you better.
Here are link that will help you with your new issue:
https://supportforums.cisco.com/docs/DOC-5711
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
Amjad
Community Member
My bad sorry,
i mean clients now get IP address, when i connect AP to wlc it gets ip address from  dhcp on my 6509, but after that its stucks, and cannot load image from wlc, i solved this problem by typing
and it worked,
but i need to make this connection for image upload dynamically, and it must be dynamically, any ideas?
thank you
Re: help dhcp wlc urgent
If the aap on same subnet as wlc it should work be connecting it to the network.
If on different subnet then you need to tell the ap about the ip address of thw wlc.
One method is to statically configure the ap withthe wlc ip, just like you did.
Other methods may be dhcp option 43 or dns (otap is one not-recommended method).
Visit the link i sent to you and you'll know more about those methods.
Amjad
Bronze
Karman,
a note I saw on your WLC
when you use option 43 in your DHCP server, you need to use TLV which are
Type= 0xf1
length= # of controller IP addresses (You have 2 IP)
Value= Convert the IP manager address to hex.
to convert 172.16.10.99 to hex =AC100A63
so the DHCP TLV would be f108.ac10.0a63
                                  yours is f108.ac01.0a63
maybe you want to fix that i guess. and check.
I had trouble with with the DHCP Proxy feauter, after I turned it of I got an IP from my external DHCP server, not a Switch and MS one over the relay option in my network...
(Cisco Controller) >config dhcp proxy enable
(Cisco Controller) >show dhcp proxy
DHCP Proxy Behavior: enabled
regards,
Sebastian
706
