Community Member
Help, I am in MBSSID VLAN Limbo
Hello all,
I'm running a cisco 1200 series with IOS 12.3(4) authenticating via PEAP with a self-signed cert back to Windows 2003 IAS. I have everything working like a top with a single global SSID
however now i'm trying to add a guest network and when I begin enabling MBSSID I start getting VLAN errors and my radio won't come up.
I have a few questions maybe you smarter fellas can answer off the top of your head:
#1 - can I run multiples SSIDs without a VLAN switch on my network? (the only cisco I have on my network is this 1200 AP)
#2 - why do I get: [ DOT11-4-NO_MBSSID_VLAN: No VLANs configured in MBSSID mode ] after I add a second SSID?
#3 - why do I get: [ DOT11-4-NO_SSID_VLAN: No SSID with VLAN configured ] after other configurations?
Here's my working config:
Current configuration : 4166 bytes
version 12.3
no service pad
service password-encryption
hostname AP
enable secret 5 ...
enable password 7 ...
username Cisco password 7 096F471A1A0A
username ...
ip subnet-zero
no ip domain lookup
ip domain name MyCompany.com
aaa new-model
aaa group server radius Server-group-1
server 10.0.1.50 auth-port 1645 acct-port 1646
aaa authentication login default local
aaa authentication login eap_methods group Server-group-1
aaa authorization exec default local
aaa session-id common
dot11 ssid MyCompany
authentication open eap eap_methods
authentication key-management wpa
mbssid guest-mode
crypto ca trustpoint TP-self-signed-1624227575
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1624227575
revocation-check none
rsakeypair TP-self-signed-1624227575
crypto ca certificate chain TP-self-signed-1624227575
certificate self-signed 01
quit
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid MyCompany
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
no dot11 extension aironet
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
speed auto
half-duplex
bridge-group 1
interface BVI1
description Bridge Virtual Interface 1
ip address 10.0.1.42 255.255.255.0
no ip route-cache
ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
radius-server host 10.0.1.50 auth-port 1645 acct-port 1646 key 7 ...
radius-server retransmit 2
radius-server timeout 4
radius-server deadtime 1
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
password 7 ...
transport preferred all
transport output all
line vty 0 4
password 7 ...
transport input all
line vty 5 15
transport input all
end
NOW - when I do this:
AP# configure terminal
AP(config)# dot11 ssid MyCompany_Guest
AP(config-ssid)# accounting accounting-method-list
AP(config-ssid)# max-associations 15
AP(config-ssid)# vlan 3762
AP(config-ssid)# exit
AP(config)# interface dot11radio 0
AP(config-if)# ssid MyCompany_Guest
I get the message:
Why?
Can anyone explain in english?
Thanks Much
Bart
Community Member
Re: Help, I am in MBSSID VLAN Limbo
Hello Bart,
The problem was You try to specify VLAN to SSID but you do not have create VLAN on AP.
So you need to create VLAN on AP first.
To Create VLAN go to SERVICES -> VLAN or use the following commands
interface Dot11Radio0.3762
encapsulation dot1Q 3762
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
bridge-group 255 spanning-disabled
interface FastEthernet0.3762
no ip route-cache
bridge-group 255
Please remember that switch port that connect to AP must set to dot1q trunk and the native VLAN of this trunk must be AP management VLAN.
Hope this will hep You.
Weerapatr
Community Member
Ok, Starting with the above config, which works with my current infrastructure
(Interface Dot11Radio0, Station 0019.d209.12d0 Associated KEY_MGMT[WPA])
First I apply your settings:
no ip route-cache
bridge-group 255
no ip route-cache
bridge-group 255
console says %DOT11-4-NO_SSID_VLAN: No SSID with VLAN configured.
So at this point I assume I should assign my SSID to VLAN 3762...
vlan 3762
write mem
Ok the radio came back up, But now I can't authenticate to the Access Point
Let me try a reload...
Now I see the error on the console:
%DOT11-4-NO_SSID_VLAN: No SSID with VLAN configured. Dot11 Radio0 not started.
This is why I can't figure this out. Makes no sense. PLEASE HELP
Here's the running-config after reload:
Building configuration...
Current configuration : 4599 bytes
version 12.3
no service pad
hostname AP
enable secret 5 ...
username ssiadmin privilege 15 password 7 ...
ip subnet-zero
no ip domain lookup
aaa new-model
vlan 3762
mbssid guest-mode
quit
bridge irb
no ip address
no ip route-cache
short-slot-time
channel 2412
station-role root
no cdp enable
bridge-group 1
no ip route-cache
bridge-group 255
no ip address
no ip route-cache
speed auto
half-duplex
bridge-group 1
no ip route-cache
bridge-group 255
interface BVI1
no ip route-cache
ip http server
control-plane
bridge 1 route ip
Hall of Fame Super Red
Hi Bart,
Unfortunately, your Question #1 is the clincher;
Assign the SSID to a VLAN on your network. Client devices that associate using the SSID are grouped into this VLAN.*** You can assign only one SSID to a VLAN.***
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_guide_chapter09186a0080184ac9.html
Q. How many service set identifiers (SSIDs) can you have per VLAN?
A. You can have only one SSID per VLAN. The use of multiple SSIDs over a single VLAN is not supported with Aironet APs.
From this good Q&A doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_qanda_item09186a008009483e.shtml
Sorry about that,
Hope this helps!
Rob
1698
