Community Member
help on Aironet 350 AP upgrade
I have a 350AP with 12.00T, using "Aironet VxWorks to Cisco IOS Conversion Tool" I upgrade to IOS 12.2.13.
My PC has a "Intel 2200bg", I see SSID "tsunami" but I can't connect.
Ethernet led light green
Status led blinking green
As start of point, I don't use any security policy, I use default configuration on AP and no authentication and no data encryption on the client.
I spent a lot of time trying different combination, but I have no result.
Can anyone help me?
Can help me upgrading to newer IOS version?
Can I downgrade to VxWorks? it worked :-)
Thanks Marco
Silver
Re: help on Aironet 350 AP upgrade
Your 350 series access point must run one of these VxWorks firmware versions to use the upgrade image:
12.03T, 12.02T1, 12.01T1, 12.00T, 11.23T, and 11.21
http://www.cisco.com/en/US/products/hw/wireless/ps458/prod_release_note09186a00801d8227.html
http://www.cisco.com/en/US/products/hw/wireless/ps458/products_installation_guide_chapter09186a0080451858.html
Bronze
Can anyone verify the IOS Upgrade Image is not compatible with VxW 12.05T? Could these links have been published before 12.05T was available? I have been able to upgrade 12.05T VxWorks APs to IOS using the WLSE with minimal issues, other than occasional link speed/duplex detection problems using switchport PoE. Thanks!
162
