Community Member
Help to solve a cover problem
Hi all
I have a AP 1231 with 5dbi omni antenna, the problem is that the cover it?s very short, is smaller to 20 meters in area with few points of interference.
I need help to solve this situation.
attach the AP config
version 12.3
no service pad
hostname xxx
enable password
ip subnet-zero
no aaa new-model
dot11 ssid Extrusiones
vlan 3
authentication open
dot11 ssid GV1
vlan 1
authentication open
dot11 ssid Telephony
vlan 2
authentication open
guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode wep mandatory
encryption vlan 2 key 1 size 128bit xxx transmit-key
encryption vlan 2 mode wep mandatory
encryption vlan 1 key 1 size 128bit xxx transmit-key
encryption vlan 1 mode wep mandatory
encryption vlan 3 key 1 size 128bit xxx transmit-key
encryption vlan 3 mode wep mandatory
ssid Extrusiones
ssid GV1
ssid Telephony
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2422
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0.1
description RED DATOS
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
description RED VOZ
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.3
description RED Extrusiones
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
description RED VOZ
no ip route-cache
bridge-group 2
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
ip address 192.168.10.5 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login
line vty 5 15
login
end
Community Member
Re: Help to solve a cover problem
Is the antenna on the right (primary) port?
I assume the AP is set to full power also.
Community Member
Yes, the antenna is connected in the right port
thanks
Bronze
What kind of space are you trying to cover?
Is this 20 meters in open space or a building of some kind?
What is in the space and what is it constructed out of?
Assuming that the space you are trying to cover is in a building, you may have just discovered that full power doesn't mean the environment you are in will let you have coverage.
Check the antenna connection to make sure it is not loose.
Replace the antenna with one that you know works.
Do a site survey and see what the range is in your environment.
You may just need another AP...
The config you posted does not contain the power settings... Did you omit these?
Should look something like this...
power local cck 14
power local ofdm 14
Community Member
Hi Robert
as I can obtain this data from the CLI?
thanks
when you do a show run it should be listed in your config...
You set the power settings by doing the following... once logging into your AP
en
conf t
int Dot11Radio0
power local cck X
power local ofdm X
Replace x with your power value you wish to use. You can also do this in the web interface.
129
