Help trouble defaulting Aironet 1300
OK i have read through the form and found whet to do BUT i get an error
Loading "flash:/c1310-k9w7-mx.122-15.JA/c1310-k9w7-mx.122-15.JA"...#############
#####################bad mzip file, unknown zip method
Error loading "flash:/c1310-k9w7-mx.122-15.JA/c1310-k9w7-mx.122-15.JA"
Interrupt within 5 seconds to abort boot process.
Boot process terminated.
bridge:dir flash
unable to stat flash/: permission denied
Why Permisson denied
Silver
Re: Help trouble defaulting Aironet 1300
I think you are on Bridge colon Mode.And to recover from colon mode . We have to to following troubleshooting steps.
Before reloading the new firmware , first Bridge (1310) needed to be formated.But since you cannot telnet, to access Bridge you need to access it through console.On console you will see..
bridge:
Step 1.Type format flash: on the bridge and then hit enter
Step 2. Enter the set command to assign an IP address, subnet mask, and
default gateway to the access point.
Note:-The system you are using must have tftp server recomended by
Cisco.
Also load the IOS file in the tftp server.Before step 3.
Step 3.Enter the tftp_init command to prepare the access point for TFTP
bridge: tftp_init
Step 4. Enter the tar command to load and inflate the new image from your TFTP server. The command must include this information:
the -xtract option, which inflates the image when it is loaded
the IP address of your TFTP server
the directory on the TFTP server that contains the image
the name of the image
the destination for the image (the access point Flash)
Ok done all that.. seems to boot OK but i can't connect even with the default IP or setting one.
Any ideas.. would it help if i post the boot log
454
