HELP WITH DHCP INTERFACE GROUP ISSUE
  • I have a 5508 running 7.0.240.0 that has 8 subnets defined.
  • The interfaces have been grouped together.
  • The DHCP server is a microsoft server with the 8 scopes defined as a multinet
Issue:
Clients can authenticate and associate to the SSID. Some clients pull and IP and gain access to the WLAN while others get IPs but and end up with limited connectivity or sometimes pull 16 Any ideas? The DHCP pools are /22 and are not depleted.
  • WPA2 enterprise with 802.1x point to a Microsoft Radius server
  • DHCP required configured on the SSID
config interface address dynamic-interface vlan156 10.0.0.x  255.255.252.0 10.0.0.x.x.x
config interface address dynamic-interface vlan152 10.0.0.152.5 255.255.252.0 10.0.0.
config interface address dynamic-interface vlan52 10.0.0.x52.5 255.255.252.0 10.0.0.x52.254
config interface address dynamic-interface vlan56 10.0.0.x56.5 255.255.252.0 10.0.0.x59.254
config interface address dynamic-interface vlan60 10.0.0.x60.5 255.255.252.0 10.0.0.x63.254
config interface address dynamic-interface vlan144 10.0.0.x144.5 255.255.252.0 10.0.0.x147.254
config interface address dynamic-interface vlan148 10.0.0.x148.5 255.255.252.0 10.0.0.x151.254
config interface address dynamic-interface vlan36 10.0.0.x36.5 255.255.252.0 10.0.0.x36.254
config interface address dynamic-interface vlan40 10.0.0.x40.5 255.255.252.0 10.0.0.x43.254
config interface address dynamic-interface vlan44 10.0.0.x44.5 255.255.252.0 10.0.0.x47.254
config interface group interface add XXX vlan120
config interface group interface add XXX vlan124
config interface group interface add XXX vlan36
config interface group interface add XXX vlan40
config interface group interface add XXX vlan44
config interface group interface add XXX vlan56
config interface group interface add XXX vlan60
config interface group create XXX X_DHCP_POOL
The WLAN is mapped to the pool.
  • Other Wireless - Mobility Subjects
Bronze
Re:HELP WITH DHCP INTERFACE GROUP ISSUE
Could I ask why in the interface group config you added vlan 120 and 124 when these vlans are not defined in the individual interfaces. Clients that attach to vlans 120 and 124 will no get an ip
Sent from Cisco Technical Support Android App
They are both defined, I didn't copy those lines from the config.
Hall of Fame Super Silver
Re: Re:HELP WITH DHCP INTERFACE GROUP ISSUE
Your dhcp is not using super scopes correct. You have a desperate dhcp scope per subnet?
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
I'm not sure as they were configured by a different group. Does the super scope affect the distribution of IPs?
Yes it does and its doesn't work well, even if you are on the wired side and connect to a different vlan.
Scott
194
