Community Member
Help with Nokia D211 Card and Cisco AP1200/1100
Have to setup a Cisco AP1200 or 1100 to work together with Nokia D211 Card. Have tried almost everything, but nothing seems to work.
Bronze
Re: Help with Nokia D211 Card and Cisco AP1200/1100
You are encountering a known bug CSCed56365
Nokia C110 client fails to associate with Aironet AP1200 with 802.11g radio (MP21G)
The following is the workaround,
If another 802.11b compliant client is successfully associated with the AP (such
as a 350 client adapter), then the Nokia C110 adapter will succeed in the association.
Community Member
sorry I can't find any bug with that number?
120
