Hi Pranay,
High cpu utilization is usually due high broadcast traffic that hits the device. You can use packet capture to verify.
If it is the case then try to isolate vlans that causes the broadcast to the device.
Amjad
Rating useful replies is more useful than saying "Thank you"
