High failure rate on the AP350's
Has anyone else experienced a high fail rate of AP350s on the initial install or soon after.
The bad APs are constantly re-booting or the Ethernet connection will not activate. From the last batch of 30 APs, five have problems. E-mail is tim.paul@ucr.edu
  • Other Wireless - Mobility Subjects
Re: High failure rate on the AP350's
Probably just a stroke of bad luck my friend. Your Cisco rep will take care of you though, give ‘em a call.
We have seen 350's lock up switches, The access points lock up, just problems with reliability in general. Usually when I call Cisco they tell be that some Cisco equiptment "Has issues with some switches"
I hope they fix this I doubt Ill be replacing switched to make my access points happy.
145
