Community Member
Horrible roaming and connection dropping from client
Hi there,
I need help troubleshooting an issue with a particular client we have on the floors.  It's a Ergotron mobile cart on wheels.  It is running Windows XP embedded with an Atheros AR5009 wireless card running driver: 10.0.0.216.  Are deployment of Access points are 3602i's running in local mode.  All access points reside on the same controller.  The controller is running code 7.2.111.0.
The issues I'm noticing are that the client has a horrible time roaming from AP to AP.  I might lose 3 for 4 pings before the clients switches over to another AP.  Another issue is that I keep the cart in one place, it may just drop the connection completely for a second or two and then reconnect.  This means that client will show a red X in the wireless symbol in the task bar.
I have taken debugs of the client and I was wondering if someone could look through them to tell me if they see anything suspicious or wrong.
Thank You
(Cisco Controller) >debug client 74-DE-2B-31-55-22
*apfMsConnTask_2: Aug 01 10:42:23.861: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_3: Aug 01 10:42:27.683: 74:de:2b:31:55:22 Association received from mobile on AP 54:78:1a:bf:8a:90
*apfMsConnTask_3: Aug 01 10:42:27.683: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_3: Aug 01 10:42:27.683: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_3: Aug 01 10:42:27.683: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:42:27.683: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:42:27.683: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 Processing RSN IE type 48, length 20 for mobile 74:de:2b:31:55:22
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 Received RSN IE with 0 PMKIDs from mobile 74:de:2b:31:55:22
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 Found an cache entry for BSSID 84:78:ac:c0:c9:a0 in PMKID cache at index 0 of station 74:de:2b:31:55:22
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 Removing BSSID 84:78:ac:c0:c9:a0 from PMKID cache of station 74:de:2b:31:55:22
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 Resetting MSCB PMK Cache Entry 0 for station 74:de:2b:31:55:22
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [84:78:ac:c0:c9:a0]
*pemReceiveTask: Aug 01 10:42:27.684: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 Updated location for station old AP 84:78:ac:c0:c9:a0-0, new AP 54:78:1a:bf:8a:90-1
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 54:78:1a:bf:8a:90 vapId 1 apVapId 1for this client
*apfMsConnTask_3: Aug 01 10:42:27.684: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_3: Aug 01 10:42:27.685: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 54:78:1a:bf:8a:90 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_3: Aug 01 10:42:27.685: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 54:78:1a:bf:8a:90 from Associated to Associated
*apfMsConnTask_3: Aug 01 10:42:27.685: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_3: Aug 01 10:42:27.685: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 54:78:1a:bf:8a:90 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_3: Aug 01 10:42:27.685: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 54:78:1a:bf:8a:90 from Associated to Associated
*dot1xMsgTask: Aug 01 10:42:27.688: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:42:27.688: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:42:27.688: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.696: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.696: 74:de:2b:31:55:22 Received Identity Response (count=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.696: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.696: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.696: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.698: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.699: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=66) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.699: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 1 ===> 66 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.699: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 66)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.701: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.701: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 66, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.701: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.718: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.718: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=67) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.718: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 67)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.724: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.724: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 67, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.724: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.734: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.734: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=68) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.734: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 68)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.749: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.749: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 68, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.749: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.765: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.765: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=69) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.765: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 69)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.778: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.778: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 69, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.778: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Resetting MSCB PMK Cache Entry 0 for station 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Adding BSSID 54:78:1a:bf:8a:9f to PMKID cache at index 0 for station 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: New PMKID: (16)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782:      [0000] 3c 3c 08 52 58 44 e0 c8 59 1d aa 39 f5 34 95 4d
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 Disabling re-auth since PMK lifetime can take care of same.
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.782: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: 74:de:2b:31:55:22 PMK sent to mobility group
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 69)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: 74:de:2b:31:55:22 Found an cache entry for BSSID 54:78:1a:bf:8a:9f in PMKID cache at index 0 of station 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784:      [0000] 3c 3c 08 52 58 44 e0 c8 59 1d aa 39 f5 34 95 4d
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=69) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.784: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.800: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.800: 74:de:2b:31:55:22 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.800: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.801: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.801: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.801: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.840: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.840: 74:de:2b:31:55:22 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.840: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.840: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.840: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.840: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 54:78:1a:bf:8a:90 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.841: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.841: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 54:78:1a:bf:8a:90 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.841: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.841: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.843: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:42:27.843: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 54:78:1a:bf:8a:90, slot 1, interface = 13, QOS = 0
  IPv4 ACL ID = 255, IPv6 ACL ID =
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.843: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.843: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:42:27.843: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:42:27.843: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*apfLbsTask: Aug 01 10:42:28.434: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x54:78:1a:bf:8a:90
*apfLbsTask: Aug 01 10:42:28.434: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:3 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:42:28.434: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x0 ptype:0x2, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:42:28.435: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x7 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:42:28.435: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:42:28.435: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:42:28.435: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:42:28.435: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_6: Aug 01 10:43:16.560: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_4: Aug 01 10:44:16.609: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_3: Aug 01 10:44:32.418: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_0: Aug 01 10:44:51.494: 74:de:2b:31:55:22 Association received from mobile on AP 1c:e6:c7:5b:06:30
*apfMsConnTask_0: Aug 01 10:44:51.494: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_0: Aug 01 10:44:51.494: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_0: Aug 01 10:44:51.494: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:44:51.494: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:44:51.494: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:44:51.494: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_0: Aug 01 10:44:51.494: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 Found an cache entry for BSSID 54:78:1a:bf:8a:9f in PMKID cache at index 0 of station 74:de:2b:31:55:22
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 Removing BSSID 54:78:1a:bf:8a:9f from PMKID cache of station 74:de:2b:31:55:22
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 Resetting MSCB PMK Cache Entry 0 for station 74:de:2b:31:55:22
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [54:78:1a:bf:8a:90]
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 Updated location for station old AP 54:78:1a:bf:8a:90-1, new AP 1c:e6:c7:5b:06:30-1
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*pemReceiveTask: Aug 01 10:44:51.495: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 1c:e6:c7:5b:06:30 vapId 1 apVapId 1for this client
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 1c:e6:c7:5b:06:30 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:5b:06:30 from Associated to Associated
*apfMsConnTask_0: Aug 01 10:44:51.495: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Aug 01 10:44:51.496: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 1c:e6:c7:5b:06:30 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_0: Aug 01 10:44:51.496: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:5b:06:30 from Associated to Associated
*dot1xMsgTask: Aug 01 10:44:51.497: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:44:51.497: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:44:51.497: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.540: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.540: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.540: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.546: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.546: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.548: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.548: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.548: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.548: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.548: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.551: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.551: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=214) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.551: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 214 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.551: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 214)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.552: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.552: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 214, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.552: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.555: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.555: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=215) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.555: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 215)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.863: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.863: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 215, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.863: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.868: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.868: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=216) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.868: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 216)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.872: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.872: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 216, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.872: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.908: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.908: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=217) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:51.908: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 217)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.031: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.031: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 217, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.031: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.039: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.039: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=218) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.039: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 218)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.058: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.058: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 218, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.058: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.070: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.071: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=219) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.071: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 219)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.086: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.086: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 219, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.086: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.415: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.415: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=220) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.415: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 220)
*apfLbsTask: Aug 01 10:44:52.445: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x1c:e6:c7:5b:6:30
*apfLbsTask: Aug 01 10:44:52.445: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:1 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:44:52.446: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x1, eaptype:0x2 w:0x1 aalg:0x0, PMState: 8021X_REQD
*apfLbsTask: Aug 01 10:44:52.446: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:44:52.446: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:44:52.446: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:44:52.446: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:44:52.446: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.478: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.478: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 220, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.478: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.492: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.492: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=221) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.492: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 221)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.497: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.497: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 221, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.497: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.509: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.509: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.509: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.509: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.509: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 221)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=221) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.510: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.537: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.537: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.537: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.537: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.537: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.538: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.538: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.538: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.538: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.538: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 1c:e6:c7:5b:06:30 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.539: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.539: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 1c:e6:c7:5b:06:30 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.539: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.539: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.541: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:44:52.541: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  on AP 1c:e6:c7:5b:06:30, slot 1, interface = 13, QOS = 0
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.541: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.541: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.541: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.541: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:44:52.541: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITDONE (message 5 - group), replay counter 00.00.00.00.00.00.00.02
*spamApTask7: Aug 01 10:44:52.541: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:44:52.542: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:44:53.644: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:44:53.644: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:53.658: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:53.658: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:44:53.658: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP received op BOOTREQUEST (1) (len 308,vlan 0, port 13, encap 0xec03)
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP selecting relay 1 - control block settings:
                        dhcpServer: 10.74.11.78, dhcpNetmask: 0.0.0.0,
                        dhcpGateway: 0.0.0.0, dhcpRelay: 10.171.36.19  VLAN: 336
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP selected relay 1 - 10.74.11.78 (local address 10.171.36.19, gateway 10.171.36.1, VLAN 336, port 13)
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP   xid: 0xc471cc6d (3295792237), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 10.171.36.19
*DHCP Socket Task: Aug 01 10:44:55.241: 74:de:2b:31:55:22 DHCP sending REQUEST to 10.171.36.1 (len 350, port 13, vlan 336)
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP selected relay 2 - NONE
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP received op BOOTREPLY (2) (len 321,vlan 336, port 13, encap 0xec00)
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP sending REPLY to STA (len 430, port 13, vlan 0)
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP transmitting DHCP OFFER (2)
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP   xid: 0xc471cc6d (3295792237), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.171.38.171
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:44:55.242: 74:de:2b:31:55:22 DHCP   server id: 1.1.1.1  rcvd server id: 10.74.11.78
*DHCP Socket Task: Aug 01 10:44:55.243: 74:de:2b:31:55:22 DHCP received op BOOTREQUEST (1) (len 335,vlan 0, port 13, encap 0xec03)
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP selected relay 1 - 10.74.11.78 (local address 10.171.36.19, gateway 10.171.36.1, VLAN 336, port 13)
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP transmitting DHCP REQUEST (3)
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP   xid: 0xc471cc6d (3295792237), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 10.171.36.19
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP   requested ip: 10.171.38.171
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP   server id: 10.74.11.78  rcvd server id: 1.1.1.1
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP sending REQUEST to 10.171.36.1 (len 374, port 13, vlan 336)
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Aug 01 10:44:55.244: 74:de:2b:31:55:22 DHCP selected relay 2 - NONE
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP received op BOOTREPLY (2) (len 326,vlan 336, port 13, encap 0xec00)
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP sending REPLY to STA (len 430, port 13, vlan 0)
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP transmitting DHCP ACK (5)
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP   xid: 0xc471cc6d (3295792237), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.171.38.171
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:44:55.245: 74:de:2b:31:55:22 DHCP   server id: 1.1.1.1  rcvd server id: 10.74.11.78
*apfLbsTask: Aug 01 10:45:00.445: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x1c:e6:c7:5b:6:30
*apfLbsTask: Aug 01 10:45:00.445: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:1 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:45:00.445: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:45:00.445: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:45:00.445: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:45:00.445: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:45:00.445: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:45:00.445: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP received op BOOTREQUEST (1) (len 308,vlan 0, port 13, encap 0xec03)
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP selecting relay 1 - control block settings:
                        dhcpServer: 10.74.11.78, dhcpNetmask: 255.255.252.0,
                        dhcpGateway: 10.171.36.1, dhcpRelay: 10.171.36.19  VLAN: 336
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP selected relay 1 - 10.74.11.78 (local address 10.171.36.19, gateway 10.171.36.1, VLAN 336, port 13)
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP transmitting DHCP INFORM (8)
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP   xid: 0x52482d1d (1380461853), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP   ciaddr: 10.171.38.171,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 10.171.36.19
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP sending REQUEST to 10.171.36.1 (len 350, port 13, vlan 336)
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Aug 01 10:45:07.545: 74:de:2b:31:55:22 DHCP selected relay 2 - NONE
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP received op BOOTREPLY (2) (len 308,vlan 336, port 13, encap 0xec00)
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP sending REPLY to STA (len 414, port 13, vlan 0)
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP transmitting DHCP ACK (5)
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP   xid: 0x52482d1d (1380461853), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP   ciaddr: 10.171.38.171,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:45:07.546: 74:de:2b:31:55:22 DHCP   server id: 1.1.1.1  rcvd server id: 10.74.11.78
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 Reassociation received from mobile on AP 1c:e6:c7:3e:41:a0
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_2: Aug 01 10:47:45.219: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [1c:e6:c7:5b:06:30]
*pemReceiveTask: Aug 01 10:47:45.220: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 Updated location for station old AP 1c:e6:c7:5b:06:30-1, new AP 1c:e6:c7:3e:41:a0-0
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 1c:e6:c7:3e:41:a0 vapId 1 apVapId 1for this client
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 1c:e6:c7:3e:41:a0 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:3e:41:a0 from Associated to Associated
*apfMsConnTask_2: Aug 01 10:47:45.220: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_2: Aug 01 10:47:45.221: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 1c:e6:c7:3e:41:a0 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_2: Aug 01 10:47:45.221: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:3e:41:a0 from Associated to Associated
*dot1xMsgTask: Aug 01 10:47:45.225: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:47:45.225: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:47:45.225: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*apfLbsTask: Aug 01 10:47:48.465: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:0, apMac 0x1c:e6:c7:3e:41:a0
*apfLbsTask: Aug 01 10:47:48.465: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:4 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:47:48.465: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x1, eaptype:0x2 w:0x1 aalg:0x0, PMState: 8021X_REQD
*apfLbsTask: Aug 01 10:47:48.465: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x1 protocol2:0x2 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:47:48.465: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:47:48.465: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:47:48.465: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:47:48.465: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 Association received from mobile on AP 54:78:1a:bf:8a:90
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_3: Aug 01 10:47:51.389: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Deleted mobile LWAPP rule on AP [1c:e6:c7:3e:41:a0]
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 Updated location for station old AP 1c:e6:c7:3e:41:a0-0, new AP 54:78:1a:bf:8a:90-1
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Initializing policy
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 54:78:1a:bf:8a:90 vapId 1 apVapId 1for this client
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 54:78:1a:bf:8a:90 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 54:78:1a:bf:8a:90 from Associated to Associated
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 54:78:1a:bf:8a:90 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_3: Aug 01 10:47:51.390: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 54:78:1a:bf:8a:90 from Associated to Associated
*dot1xMsgTask: Aug 01 10:47:51.393: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:47:51.393: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:47:51.393: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.398: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.398: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.398: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.400: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.400: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.402: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.402: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.402: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.402: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.402: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.404: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.404: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=225) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.404: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 225 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.404: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 225)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.405: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.406: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 225, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.406: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.409: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.409: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=226) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.409: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 226)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.425: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.425: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 226, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.425: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.441: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.441: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=227) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.441: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 227)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.444: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.444: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 227, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.444: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.456: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.457: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=228) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.457: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 228)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.458: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.459: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 228, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.459: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.473: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.473: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.473: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 228)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=228) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.474: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.488: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.488: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.488: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.488: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.488: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 54:78:1a:bf:8a:90 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 54:78:1a:bf:8a:90 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.492: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.494: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:47:51.494: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.494: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.494: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.494: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.494: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:47:51.494: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:47:51.495: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*spamApTask0: Aug 01 10:47:51.495: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*osapiBsnTimer: Aug 01 10:47:52.664: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:47:52.665: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:52.825: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:52.825: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:47:52.825: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:47:56.473: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x54:78:1a:bf:8a:90
*apfLbsTask: Aug 01 10:47:56.473: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:2 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:47:56.473: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:47:56.473: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:47:56.473: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:47:56.473: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:47:56.473: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:47:56.473: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_5: Aug 01 10:48:10.382: 74:de:2b:31:55:22 Reassociation received from mobile on AP 84:78:ac:c0:cd:80
*apfMsConnTask_5: Aug 01 10:48:10.382: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_5: Aug 01 10:48:10.382: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [54:78:1a:bf:8a:90]
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 Updated location for station old AP 54:78:1a:bf:8a:90-1, new AP 84:78:ac:c0:cd:80-0
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_5: Aug 01 10:48:10.383: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_5: Aug 01 10:48:10.384: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 84:78:ac:c0:cd:80 vapId 1 apVapId 1for this client
*apfMsConnTask_5: Aug 01 10:48:10.384: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_5: Aug 01 10:48:10.384: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:cd:80 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_5: Aug 01 10:48:10.384: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:cd:80 from Associated to Associated
*apfMsConnTask_5: Aug 01 10:48:10.384: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_5: Aug 01 10:48:10.384: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 84:78:ac:c0:cd:80 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_5: Aug 01 10:48:10.384: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:cd:80 from Associated to Associated
*pemReceiveTask: Aug 01 10:48:10.384: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*dot1xMsgTask: Aug 01 10:48:10.385: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:48:10.385: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:48:10.385: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.391: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.391: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.391: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.393: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.393: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.395: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.395: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.395: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.395: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.395: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.397: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.397: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=28) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.397: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 28 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.397: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 28)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.398: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.399: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 28, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.399: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.411: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.411: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=29) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.411: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 29)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.414: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.414: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 29, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.414: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.427: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.427: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=30) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.427: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 30)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.429: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.429: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 30, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.429: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.442: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.442: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=31) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.442: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 31)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.445: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.445: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 31, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.445: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 31)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=31) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.459: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.460: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.472: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.472: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.472: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.472: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.472: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 84:78:ac:c0:cd:80 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:cd:80 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.477: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.479: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:48:10.479: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 84:78:ac:c0:cd:80, slot 0, interface = 13, QOS = 0
  IPv4 ACL ID = 255, IPv6 ACL ID =
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.479: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.480: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.480: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.480: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:48:10.480: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask6: Aug 01 10:48:10.480: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:48:10.480: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:48:11.676: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:48:11.676: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:12.292: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:12.292: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:48:12.292: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:48:12.477: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:0, apMac 0x84:78:ac:c0:cd:80
*apfLbsTask: Aug 01 10:48:12.477: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:2 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:48:12.477: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:48:12.477: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x1 protocol2:0x2 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:48:12.477: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:48:12.477: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:48:12.477: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:48:12.477: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
clear          Clear selected configuration elements.
config         Configure switch options and settings.
debug          Manages system debug options.
eping          Send Ethernet-over-IP echo packets to a specified mobility peer IP address.
help           Help
license        Manage Software License
linktest       Perform a link test to a specified MAC address.
logout         Exit this session. Any unsaved changes are lost.
mping          Send Mobility echo packets to a specified mobility peer IP address.
ping           Send ICMP echo packets to a specified IP address.
reset          Reset options.
save           Save switch configurations.
show           Display switch options and settings.
test           Test trigger commands
transfer       Transfer a file to or from the switch.
(Cisco Controller) >*apfMsConnTask_0: Aug 01 10:50:14.254: 74:de:2b:31:55:22 Association received from mobile on AP 1c:e6:c7:5b:06:30
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [84:78:ac:c0:cd:80]
*pemReceiveTask: Aug 01 10:50:14.255: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 Updated location for station old AP 84:78:ac:c0:cd:80-0, new AP 1c:e6:c7:5b:06:30-1
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_0: Aug 01 10:50:14.255: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:50:14.256: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:50:14.256: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 1c:e6:c7:5b:06:30 vapId 1 apVapId 1for this client
*apfMsConnTask_0: Aug 01 10:50:14.256: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Aug 01 10:50:14.256: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 1c:e6:c7:5b:06:30 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_0: Aug 01 10:50:14.256: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:5b:06:30 from Associated to Associated
*apfMsConnTask_0: Aug 01 10:50:14.256: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Aug 01 10:50:14.256: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 1c:e6:c7:5b:06:30 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_0: Aug 01 10:50:14.256: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:5b:06:30 from Associated to Associated
*dot1xMsgTask: Aug 01 10:50:14.257: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:50:14.257: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:50:14.257: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.269: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.269: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.269: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.272: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.272: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.274: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.274: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.274: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.274: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.274: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.276: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.276: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=112) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.276: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 112 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.276: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 112)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.278: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.278: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 112, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.278: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.280: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.280: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=113) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.280: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 113)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.293: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.293: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 113, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.293: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.295: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.295: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=114) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.295: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 114)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.298: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.298: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 114, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.298: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.300: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.300: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=115) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.300: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 115)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.302: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.302: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 115, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.302: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 115)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=115) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.305: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.306: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.318: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.318: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.318: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.318: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.318: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 1c:e6:c7:5b:06:30 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 1c:e6:c7:5b:06:30 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.322: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.324: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:50:14.324: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.324: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.324: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.325: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.325: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:50:14.325: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask7: Aug 01 10:50:14.325: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:50:14.325: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:50:15.476: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:50:15.477: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:15.519: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:15.519: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:50:15.519: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:50:20.477: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x1c:e6:c7:5b:6:30
*apfLbsTask: Aug 01 10:50:20.477: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:5 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:50:20.477: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:50:20.477: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:50:20.477: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:50:20.477: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:50:20.477: 74:de:2b:31:55:22 Copy CCX LOCP 5
Incorrect usage.  Use the '?' or <TAB> key to list commands.
(Cisco Controller) >*apfLbsTask: Aug 01 10:50:20.477: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_0: Aug 01 10:51:16.123: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_7: Aug 01 10:51:54.840: 74:de:2b:31:55:22 Reassociation received from mobile on AP 1c:e6:c7:5b:29:50
*apfMsConnTask_7: Aug 01 10:51:54.840: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_7: Aug 01 10:51:54.840: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_7: Aug 01 10:51:54.840: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:51:54.840: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:51:54.840: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:51:54.840: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_7: Aug 01 10:51:54.840: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [1c:e6:c7:5b:06:30]
*pemReceiveTask: Aug 01 10:51:54.841: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 Updated location for station old AP 1c:e6:c7:5b:06:30-1, new AP 1c:e6:c7:5b:29:50-1
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 1c:e6:c7:5b:29:50 vapId 1 apVapId 1for this client
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 1c:e6:c7:5b:29:50 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:5b:29:50 from Associated to Associated
*apfMsConnTask_7: Aug 01 10:51:54.841: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_7: Aug 01 10:51:54.842: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 1c:e6:c7:5b:29:50 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_7: Aug 01 10:51:54.842: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:5b:29:50 from Associated to Associated
*dot1xMsgTask: Aug 01 10:51:54.844: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:51:54.844: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:51:54.844: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.849: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.849: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.849: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.851: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.851: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.853: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.853: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.853: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.853: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.853: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.855: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.855: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=127) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.855: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 127 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.855: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 127)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.857: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.857: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 127, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.857: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.862: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.862: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=128) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.862: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 128)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.872: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.872: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 128, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.872: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.878: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.878: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=129) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.878: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 129)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.881: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.881: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 129, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.881: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.893: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.893: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=130) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.893: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 130)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.895: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.895: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 130, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.895: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.910: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 130)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.911: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.911: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.911: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=130) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.911: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.911: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.924: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.924: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.924: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.924: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.924: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.931: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.931: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.931: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.931: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.932: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 1c:e6:c7:5b:29:50 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.932: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.932: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 1c:e6:c7:5b:29:50 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.932: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.932: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.934: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:51:54.934: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  on AP 1c:e6:c7:5b:29:50, slot 1, interface = 13, QOS = 0
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.934: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.934: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.934: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.934: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:51:54.934: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITDONE (message 5 - group), replay counter 00.00.00.00.00.00.00.02
*spamApTask0: Aug 01 10:51:54.934: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:51:54.935: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:51:56.084: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:51:56.084: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:56.100: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:56.100: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:51:56.100: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:51:56.485: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x1c:e6:c7:5b:29:50
*apfLbsTask: Aug 01 10:51:56.485: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:2 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:51:56.485: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:51:56.485: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:51:56.485: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:51:56.485: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:51:56.485: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:51:56.485: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 Reassociation received from mobile on AP 1c:e6:c7:e1:82:c0
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_6: Aug 01 10:52:02.497: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [1c:e6:c7:5b:29:50]
*pemReceiveTask: Aug 01 10:52:02.498: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 Updated location for station old AP 1c:e6:c7:5b:29:50-1, new AP 1c:e6:c7:e1:82:c0-1
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 1c:e6:c7:e1:82:c0 vapId 1 apVapId 1for this client
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 1c:e6:c7:e1:82:c0 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:e1:82:c0 from Associated to Associated
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_6: Aug 01 10:52:02.498: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 1c:e6:c7:e1:82:c0 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_6: Aug 01 10:52:02.499: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 1c:e6:c7:e1:82:c0 from Associated to Associated
*dot1xMsgTask: Aug 01 10:52:02.500: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:52:02.500: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:52:02.500: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.506: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.506: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.506: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.508: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.508: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.510: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.510: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.510: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.510: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.510: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.513: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.513: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=150) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.513: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 150 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.513: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 150)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.514: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.514: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 150, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.514: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.519: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.519: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=151) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.519: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 151)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.529: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.529: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 151, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.529: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.535: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.535: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=152) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.535: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 152)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.537: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.537: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 152, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.537: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.550: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.550: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=153) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.550: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 153)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.552: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.552: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 153, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.552: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 153)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=153) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.567: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.568: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.580: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.580: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.580: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.580: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.580: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.584: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.584: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.584: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.584: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.585: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 1c:e6:c7:e1:82:c0 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.585: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.585: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 1c:e6:c7:e1:82:c0 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.585: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.585: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.587: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:52:02.587: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  on AP 1c:e6:c7:e1:82:c0, slot 1, interface = 13, QOS = 0
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.587: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.587: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.587: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.587: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:52:02.587: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask5: Aug 01 10:52:02.587: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:52:02.587: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:52:03.684: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:52:03.685: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:03.694: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:03.694: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:03.695: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:52:04.485: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x1c:e6:c7:e1:82:c0
*apfLbsTask: Aug 01 10:52:04.485: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:4 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:52:04.485: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:52:04.485: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:52:04.486: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:52:04.486: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:52:04.486: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:52:04.486: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_3: Aug 01 10:52:57.195: 74:de:2b:31:55:22 Reassociation received from mobile on AP 84:78:ac:c0:cb:80
*apfMsConnTask_3: Aug 01 10:52:57.195: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_3: Aug 01 10:52:57.195: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_3: Aug 01 10:52:57.195: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:52:57.195: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:52:57.195: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [1c:e6:c7:e1:82:c0]
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 Updated location for station old AP 1c:e6:c7:e1:82:c0-1, new AP 84:78:ac:c0:cb:80-0
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 84:78:ac:c0:cb:80 vapId 1 apVapId 1for this client
*apfMsConnTask_3: Aug 01 10:52:57.196: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_3: Aug 01 10:52:57.197: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:cb:80 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_3: Aug 01 10:52:57.197: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:cb:80 from Associated to Associated
*apfMsConnTask_3: Aug 01 10:52:57.197: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_3: Aug 01 10:52:57.197: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 84:78:ac:c0:cb:80 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_3: Aug 01 10:52:57.197: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:cb:80 from Associated to Associated
*pemReceiveTask: Aug 01 10:52:57.198: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*dot1xMsgTask: Aug 01 10:52:57.201: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:52:57.201: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:52:57.201: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.205: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.205: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.205: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.206: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.206: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.208: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.209: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.209: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.209: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.209: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.211: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.211: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=56) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.211: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 56 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.211: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 56)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.212: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.212: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 56, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.212: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.225: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.225: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=57) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.225: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 57)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.228: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.228: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 57, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.228: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.241: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.241: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=58) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.241: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 58)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.244: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.244: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 58, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.244: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.256: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.257: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=59) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.257: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 59)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.258: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.258: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 59, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.258: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.273: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.273: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.273: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.273: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.273: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 59)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=59) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.274: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.286: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.286: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.286: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.286: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.287: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.294: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.294: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.294: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.295: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.295: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 84:78:ac:c0:cb:80 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.295: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.295: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:cb:80 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.295: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.295: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.297: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:52:57.297: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 84:78:ac:c0:cb:80, slot 0, interface = 13, QOS = 0
  IPv4 ACL ID = 255, IPv6 ACL ID =
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.297: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.297: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.297: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.297: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:52:57.297: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask7: Aug 01 10:52:57.297: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:52:57.298: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:52:58.484: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:52:58.484: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:58.498: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:58.498: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:52:58.498: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:53:00.485: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:0, apMac 0x84:78:ac:c0:cb:80
*apfLbsTask: Aug 01 10:53:00.485: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:22 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:53:00.485: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:53:00.485: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x1 protocol2:0x2 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:53:00.485: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:53:00.485: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:53:00.485: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:53:00.485: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 Association received from mobile on AP 84:78:ac:c0:cb:80
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_3: Aug 01 10:53:02.836: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*pemReceiveTask: Aug 01 10:53:02.837: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 84:78:ac:c0:cb:80 vapId 1 apVapId 1for this client
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:cb:80 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:cb:80 from Associated to Associated
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 84:78:ac:c0:cb:80 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_3: Aug 01 10:53:02.837: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:cb:80 from Associated to Associated
*dot1xMsgTask: Aug 01 10:53:02.838: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:53:02.839: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:53:02.839: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.850: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.850: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.850: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.852: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.852: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.854: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.854: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.854: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.854: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.854: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.856: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.856: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=66) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.856: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 66 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.856: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 66)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.858: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.858: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 66, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.858: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.860: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.860: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=67) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.860: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 67)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.872: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.872: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 67, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.872: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.874: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.874: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=68) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.874: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 68)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.877: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.877: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 68, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.877: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.879: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.879: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=69) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.879: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 69)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.881: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.881: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 69, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.881: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.884: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 69)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=69) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.885: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.898: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.898: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.898: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.898: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.898: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.902: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.902: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.902: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.902: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.902: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 84:78:ac:c0:cb:80 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.903: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.903: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:cb:80 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.903: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.903: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.905: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:53:02.905: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.905: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.905: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.905: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.905: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.905: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask7: Aug 01 10:53:02.906: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:53:02.906: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.922: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.922: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:02.922: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:53:08.486: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:0, apMac 0x84:78:ac:c0:cb:80
*apfLbsTask: Aug 01 10:53:08.486: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:22 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:53:08.486: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:53:08.486: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x1 protocol2:0x2 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:53:08.486: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:53:08.486: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:53:08.486: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:53:08.486: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_0: Aug 01 10:53:16.954: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 Association received from mobile on AP 0c:d9:96:05:de:90
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Aug 01 10:53:24.200: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [84:78:ac:c0:cb:80]
*pemReceiveTask: Aug 01 10:53:24.201: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 Updated location for station old AP 84:78:ac:c0:cb:80-0, new AP 0c:d9:96:05:de:90-1
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1for this client
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 0c:d9:96:05:de:90 from Associated to Associated
*apfMsConnTask_0: Aug 01 10:53:24.201: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Aug 01 10:53:24.202: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 0c:d9:96:05:de:90 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_0: Aug 01 10:53:24.202: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 0c:d9:96:05:de:90 from Associated to Associated
*dot1xMsgTask: Aug 01 10:53:24.203: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:53:24.203: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:53:24.203: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.209: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.209: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.209: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.210: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.211: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.212: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.213: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.213: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.213: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.213: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.215: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.216: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=125) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.216: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 125 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.216: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 125)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.217: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.217: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 125, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.217: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.227: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.227: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=126) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.227: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 126)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.231: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.231: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 126, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.231: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.244: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.244: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=127) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.244: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 127)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.246: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.246: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 127, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.246: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.258: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.258: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=128) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.258: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 128)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.260: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.260: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 128, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.260: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.275: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 128)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.276: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.276: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.276: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=128) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.276: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.276: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.288: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.288: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.288: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.288: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.288: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.292: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.292: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.292: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.292: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.292: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.292: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.293: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.293: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.293: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.295: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:53:24.295: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  on AP 0c:d9:96:05:de:90, slot 1, interface = 13, QOS = 0
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.295: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.295: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.295: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.295: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:53:24.295: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask6: Aug 01 10:53:24.296: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:53:24.296: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*apfLbsTask: Aug 01 10:53:24.494: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0xc:d9:96:5:de:90
*apfLbsTask: Aug 01 10:53:24.494: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:2 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:53:24.494: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:53:24.494: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:53:24.494: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:53:24.494: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:53:24.494: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:53:24.494: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*osapiBsnTimer: Aug 01 10:53:25.489: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:53:25.489: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:25.642: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:25.642: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:25.642: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 Association received from mobile on AP 40:f4:ec:a3:2a:e0
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_1: Aug 01 10:53:34.060: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [0c:d9:96:05:de:90]
*pemReceiveTask: Aug 01 10:53:34.061: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 Updated location for station old AP 0c:d9:96:05:de:90-1, new AP 40:f4:ec:a3:2a:e0-1
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 40:f4:ec:a3:2a:e0 vapId 1 apVapId 1for this client
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 40:f4:ec:a3:2a:e0 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 40:f4:ec:a3:2a:e0 from Associated to Associated
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 40:f4:ec:a3:2a:e0 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_1: Aug 01 10:53:34.061: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 40:f4:ec:a3:2a:e0 from Associated to Associated
*dot1xMsgTask: Aug 01 10:53:34.063: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:53:34.063: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:53:34.063: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.078: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.078: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.078: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.081: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.081: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.141: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.141: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.141: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.141: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.141: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.143: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.143: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=152) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.144: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 152 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.144: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 152)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.145: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.146: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 152, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.146: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.149: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.149: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=153) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.149: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 153)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.160: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.160: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 153, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.160: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.165: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.165: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=154) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.165: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 154)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.168: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.168: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 154, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.168: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.181: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.181: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=155) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.181: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 155)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.182: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.183: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 155, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.183: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.197: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 155)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=155) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.198: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.210: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.210: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.210: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.210: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.210: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 40:f4:ec:a3:2a:e0 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 40:f4:ec:a3:2a:e0 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.214: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.216: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:53:34.216: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  on AP 40:f4:ec:a3:2a:e0, slot 1, interface = 13, QOS = 0
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.216: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.216: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.216: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.216: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.216: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITDONE (message 5 - group), replay counter 00.00.00.00.00.00.00.02
*spamApTask2: Aug 01 10:53:34.216: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:53:34.217: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.253: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.253: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:53:34.253: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:53:40.493: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x40:f4:ec:a3:2a:e0
*apfLbsTask: Aug 01 10:53:40.494: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:15 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:53:40.494: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:53:40.494: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:53:40.494: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:53:40.494: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:53:40.494: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:53:40.494: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
clear          Clear selected configuration elements.
config         Configure switch options and settings.
debug          Manages system debug options.
eping          Send Ethernet-over-IP echo packets to a specified mobility peer IP address.
help           Help
license        Manage Software License
linktest       Perform a link test to a specified MAC address.
logout         Exit this session. Any unsaved changes are lost.
mping          Send Mobility echo packets to a specified mobility peer IP address.
ping           Send ICMP echo packets to a specified IP address.
reset          Reset options.
save           Save switch configurations.
show           Display switch options and settings.
test           Test trigger commands
transfer       Transfer a file to or from the switch.
(Cisco Controller) >Stopping retransmission timer for mobile 74:de:2b:31:55:22
Incorrect usage.  Use the '?' or <TAB> key to list commands.
(Cisco Controller) >*apfMsConnTask_0: Aug 01 10:54:40.891: 74:de:2b:31:55:22 Reassociation received from mobile on AP 0c:d9:96:05:de:90
*apfMsConnTask_0: Aug 01 10:54:40.891: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_0: Aug 01 10:54:40.891: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [40:f4:ec:a3:2a:e0]
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 Updated location for station old AP 40:f4:ec:a3:2a:e0-1, new AP 0c:d9:96:05:de:90-1
*pemReceiveTask: Aug 01 10:54:40.892: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:54:40.892: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1for this client
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 0c:d9:96:05:de:90 from Associated to Associated
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 0c:d9:96:05:de:90 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_0: Aug 01 10:54:40.893: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 0c:d9:96:05:de:90 from Associated to Associated
*dot1xMsgTask: Aug 01 10:54:40.895: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:54:40.895: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:54:40.895: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.900: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.900: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.900: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.904: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.904: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.906: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.906: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.906: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.906: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.906: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.908: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.908: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=88) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.908: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 88 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.908: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 88)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.910: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.910: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 88, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.910: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.919: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.919: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=89) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.919: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 89)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.924: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.924: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 89, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.925: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.935: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.935: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=90) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.935: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 90)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.937: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.938: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 90, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.938: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.950: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.950: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=91) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.950: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 91)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.952: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.952: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 91, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.952: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.967: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.967: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.967: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.967: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.967: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.967: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.967: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.967: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.968: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 91)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.968: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.968: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.968: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=91) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.968: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.968: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.980: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.981: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.981: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.981: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.981: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.985: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.985: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.985: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.985: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.985: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.985: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.985: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.985: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.986: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.987: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:54:40.988: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.988: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.988: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.988: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.988: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:54:40.988: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask6: Aug 01 10:54:40.988: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:54:40.988: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:54:42.092: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:54:42.092: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*osapiBsnTimer: Aug 01 10:54:43.092: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:54:43.092: 74:de:2b:31:55:22 Retransmit 2 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*osapiBsnTimer: Aug 01 10:54:44.092: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:54:44.092: 74:de:2b:31:55:22 Retransmit failure for EAPOL-Key M5 to mobile 74:de:2b:31:55:22, retransmit count 3, mscb deauth count 0
*dot1xMsgTask: Aug 01 10:54:44.092: 74:de:2b:31:55:22 Resetting MSCB PMK Cache Entry 0 for station 74:de:2b:31:55:22
*dot1xMsgTask: Aug 01 10:54:44.092: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*dot1xMsgTask: Aug 01 10:54:44.094: 74:de:2b:31:55:22 Sent Deauthenticate to mobile on BSSID 0c:d9:96:05:de:90 slot 1(caller 1x_ptsm.c:546)
*dot1xMsgTask: Aug 01 10:54:44.094: 74:de:2b:31:55:22 Scheduling deletion of Mobile Station:  (callerId: 57) in 10 seconds
*apfLbsTask: Aug 01 10:54:44.493: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0xc:d9:96:5:de:90
*apfLbsTask: Aug 01 10:54:44.493: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:2 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:54:44.493: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:54:44.493: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:54:44.493: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:54:44.493: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:54:44.494: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:54:44.494: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 Association received from mobile on AP 0c:d9:96:05:de:90
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_0: Aug 01 10:54:45.987: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1for this client
*apfMsConnTask_0: Aug 01 10:54:45.988: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Aug 01 10:54:45.988: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 0c:d9:96:05:de:90 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_0: Aug 01 10:54:45.988: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 0c:d9:96:05:de:90 from Associated to Associated
*apfMsConnTask_0: Aug 01 10:54:45.988: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Aug 01 10:54:45.988: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 0c:d9:96:05:de:90 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_0: Aug 01 10:54:45.988: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 0c:d9:96:05:de:90 from Associated to Associated
*pemReceiveTask: Aug 01 10:54:45.988: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*dot1xMsgTask: Aug 01 10:54:45.989: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:54:45.989: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*dot1xMsgTask: Aug 01 10:54:45.989: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:54:45.989: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*apfMsConnTask_6: Aug 01 10:54:48.113: 74:de:2b:31:55:22 Reassociation received from mobile on AP 84:78:ac:98:ae:00
*apfMsConnTask_6: Aug 01 10:54:48.113: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_6: Aug 01 10:54:48.113: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_6: Aug 01 10:54:48.113: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_6: Aug 01 10:54:48.113: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_6: Aug 01 10:54:48.113: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Deleted mobile LWAPP rule on AP [0c:d9:96:05:de:90]
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 Updated location for station old AP 0c:d9:96:05:de:90-1, new AP 84:78:ac:98:ae:00-1
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Initializing policy
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 84:78:ac:98:ae:00 vapId 1 apVapId 1for this client
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 84:78:ac:98:ae:00 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_6: Aug 01 10:54:48.114: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:98:ae:00 from Associated to Associated
*apfMsConnTask_6: Aug 01 10:54:48.115: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_6: Aug 01 10:54:48.115: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 84:78:ac:98:ae:00 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_6: Aug 01 10:54:48.115: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:98:ae:00 from Associated to Associated
*dot1xMsgTask: Aug 01 10:54:48.116: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:54:48.116: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:54:48.116: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.694: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.694: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.694: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.710: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.710: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.712: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.712: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.712: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.712: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.712: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.715: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.715: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=113) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.715: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 113 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.715: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 113)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.716: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.716: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 113, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.716: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.732: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.732: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=114) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.732: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 114)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.734: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.734: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 114, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.734: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.748: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.748: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=115) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.748: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 115)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.752: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.752: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 115, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.752: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.763: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.763: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=116) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.763: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 116)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.765: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.765: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 116, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.765: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 116)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=116) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.781: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.793: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.793: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.793: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.793: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.793: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 84:78:ac:98:ae:00 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 84:78:ac:98:ae:00 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.798: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.800: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:54:49.800: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 84:78:ac:98:ae:00, slot 1, interface = 13, QOS = 0
  IPv4 ACL ID = 255, IPv6 ACL ID =
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.800: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.800: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.800: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.800: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:54:49.800: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:54:49.800: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*spamApTask1: Aug 01 10:54:49.801: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*osapiBsnTimer: Aug 01 10:54:50.896: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:54:50.897: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:50.954: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:50.954: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:54:50.954: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:54:51.145: 74:de:2b:31:55:22 DHCP received op BOOTREQUEST (1) (len 323,vlan 0, port 13, encap 0xec03)
*DHCP Socket Task: Aug 01 10:54:51.145: 74:de:2b:31:55:22 DHCP selecting relay 1 - control block settings:
                        dhcpServer: 10.74.11.78, dhcpNetmask: 255.255.252.0,
                        dhcpGateway: 10.171.36.1, dhcpRelay: 10.171.36.19  VLAN: 336
*DHCP Socket Task: Aug 01 10:54:51.145: 74:de:2b:31:55:22 DHCP selected relay 1 - 10.74.11.78 (local address 10.171.36.19, gateway 10.171.36.1, VLAN 336, port 13)
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP transmitting DHCP REQUEST (3)
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP   xid: 0xc65aa372 (3327828850), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP   ciaddr: 10.171.38.171,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 10.171.36.19
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP sending REQUEST to 10.171.36.1 (len 366, port 13, vlan 336)
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Aug 01 10:54:51.146: 74:de:2b:31:55:22 DHCP selected relay 2 - NONE
*DHCP Socket Task: Aug 01 10:54:51.147: 74:de:2b:31:55:22 DHCP received op BOOTREPLY (2) (len 326,vlan 336, port 13, encap 0xec00)
*DHCP Socket Task: Aug 01 10:54:51.147: 74:de:2b:31:55:22 DHCP sending REPLY to STA (len 430, port 13, vlan 0)
*DHCP Socket Task: Aug 01 10:54:51.147: 74:de:2b:31:55:22 DHCP transmitting DHCP ACK (5)
*DHCP Socket Task: Aug 01 10:54:51.147: 74:de:2b:31:55:22 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 01 10:54:51.148: 74:de:2b:31:55:22 DHCP   xid: 0xc65aa372 (3327828850), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:54:51.148: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:54:51.148: 74:de:2b:31:55:22 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.171.38.171
*DHCP Socket Task: Aug 01 10:54:51.148: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:54:51.148: 74:de:2b:31:55:22 DHCP   server id: 1.1.1.1  rcvd server id: 10.74.11.78
*apfLbsTask: Aug 01 10:54:52.497: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x84:78:ac:98:ae:0
*apfLbsTask: Aug 01 10:54:52.497: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:1 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:54:52.497: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:54:52.497: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:54:52.497: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:54:52.497: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:54:52.497: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:54:52.497: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*DHCP Socket Task: Aug 01 10:54:57.138: 74:de:2b:31:55:22 DHCP received op BOOTREQUEST (1) (len 323,vlan 0, port 13, encap 0xec03)
*DHCP Socket Task: Aug 01 10:54:57.138: 74:de:2b:31:55:22 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Aug 01 10:54:57.138: 74:de:2b:31:55:22 DHCP selected relay 1 - 10.74.11.78 (local address 10.171.36.19, gateway 10.171.36.1, VLAN 336, port 13)
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP transmitting DHCP REQUEST (3)
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP   xid: 0x74c21d69 (1958878569), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP   ciaddr: 10.171.38.171,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 10.171.36.19
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP sending REQUEST to 10.171.36.1 (len 366, port 13, vlan 336)
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP selected relay 2 - NONE
*DHCP Socket Task: Aug 01 10:54:57.139: 74:de:2b:31:55:22 DHCP received op BOOTREPLY (2) (len 326,vlan 336, port 13, encap 0xec00)
*DHCP Socket Task: Aug 01 10:54:57.140: 74:de:2b:31:55:22 DHCP sending REPLY to STA (len 430, port 13, vlan 0)
*DHCP Socket Task: Aug 01 10:54:57.140: 74:de:2b:31:55:22 DHCP transmitting DHCP ACK (5)
*DHCP Socket Task: Aug 01 10:54:57.140: 74:de:2b:31:55:22 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 01 10:54:57.140: 74:de:2b:31:55:22 DHCP   xid: 0x74c21d69 (1958878569), secs: 0, flags: 0
*DHCP Socket Task: Aug 01 10:54:57.140: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:54:57.140: 74:de:2b:31:55:22 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.171.38.171
*DHCP Socket Task: Aug 01 10:54:57.140: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:54:57.140: 74:de:2b:31:55:22 DHCP   server id: 1.1.1.1  rcvd server id: 10.74.11.78
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP received op BOOTREQUEST (1) (len 556,vlan 0, port 13, encap 0xec03)
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP selected relay 1 - 10.74.11.78 (local address 10.171.36.19, gateway 10.171.36.1, VLAN 336, port 13)
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP transmitting DHCP INFORM (8)
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP   xid: 0x29000000 (687865856), secs: 0, flags: 8000
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP   ciaddr: 10.171.38.171,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 10.171.36.19
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP sending REQUEST to 10.171.36.1 (len 350, port 13, vlan 336)
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Aug 01 10:54:59.690: 74:de:2b:31:55:22 DHCP selected relay 2 - NONE
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP received op BOOTREPLY (2) (len 308,vlan 336, port 13, encap 0xec00)
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP sending REPLY to STA (len 414, port 13, vlan 0)
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP transmitting DHCP ACK (5)
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP   xid: 0x29000000 (687865856), secs: 0, flags: 8000
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP   chaddr: 74:de:2b:31:55:22
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP   ciaddr: 10.171.38.171,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Aug 01 10:54:59.691: 74:de:2b:31:55:22 DHCP   server id: 1.1.1.1  rcvd server id: 10.74.11.78
*apfMsConnTask_0: Aug 01 10:55:17.339: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_1: Aug 01 10:56:59.381: 74:de:2b:31:55:22 Reassociation received from mobile on AP 40:f4:ec:a3:2a:e0
*apfMsConnTask_1: Aug 01 10:56:59.381: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_1: Aug 01 10:56:59.381: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_1: Aug 01 10:56:59.381: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [84:78:ac:98:ae:00]
*pemReceiveTask: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 Updated location for station old AP 84:78:ac:98:ae:00-1, new AP 40:f4:ec:a3:2a:e0-1
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 40:f4:ec:a3:2a:e0 vapId 1 apVapId 1for this client
*apfMsConnTask_1: Aug 01 10:56:59.382: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_1: Aug 01 10:56:59.383: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 40:f4:ec:a3:2a:e0 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_1: Aug 01 10:56:59.383: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 40:f4:ec:a3:2a:e0 from Associated to Associated
*apfMsConnTask_1: Aug 01 10:56:59.383: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_1: Aug 01 10:56:59.383: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 40:f4:ec:a3:2a:e0 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_1: Aug 01 10:56:59.383: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 40:f4:ec:a3:2a:e0 from Associated to Associated
*dot1xMsgTask: Aug 01 10:56:59.403: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:56:59.403: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:56:59.403: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:56:59.589: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:56:59.589: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:56:59.589: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:56:59.590: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:56:59.590: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.000: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.000: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.000: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.000: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.000: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.002: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.002: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=203) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.002: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 203 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.002: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 203)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.003: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.003: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 203, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.003: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.005: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.005: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=204) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.005: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 204)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.016: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.016: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 204, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.016: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.018: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.018: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=205) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.018: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 205)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.020: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.020: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 205, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.020: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.022: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.022: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=206) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.023: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 206)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.024: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.024: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 206, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.024: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 206)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=206) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.028: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.038: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.038: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.038: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.038: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.038: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 40:f4:ec:a3:2a:e0 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 40:f4:ec:a3:2a:e0 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.043: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.045: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:57:00.045: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.045: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.045: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.045: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.045: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.045: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask2: Aug 01 10:57:00.046: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:57:00.046: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 Reassociation received from mobile on AP 84:78:ac:c0:c7:90
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [40:f4:ec:a3:2a:e0]
*pemReceiveTask: Aug 01 10:57:00.471: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 Updated location for station old AP 40:f4:ec:a3:2a:e0-1, new AP 84:78:ac:c0:c7:90-1
*apfMsConnTask_7: Aug 01 10:57:00.471: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1for this client
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:c7:90 from Associated to Associated
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 84:78:ac:c0:c7:90 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_7: Aug 01 10:57:00.472: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:c7:90 from Associated to Associated
*dot1xMsgTask: Aug 01 10:57:00.473: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:57:00.474: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:57:00.474: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.478: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.478: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.478: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.478: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.478: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.480: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.480: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.480: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.480: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.480: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.483: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.483: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=206) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.483: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 206 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.483: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 206)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.484: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.484: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 206, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.484: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.486: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.486: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=207) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.486: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 207)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.494: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.494: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 207, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.494: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.496: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.497: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=208) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.497: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 208)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.499: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.499: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 208, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.499: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.501: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.501: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=209) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.501: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 209)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.502: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.502: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 209, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.502: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:57:00.505: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x84:78:ac:c0:c7:90
*apfLbsTask: Aug 01 10:57:00.505: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:1 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:57:00.505: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x1, eaptype:0x2 w:0x1 aalg:0x0, PMState: 8021X_REQD
*apfLbsTask: Aug 01 10:57:00.505: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:57:00.505: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:57:00.505: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:57:00.505: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.506: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 209)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.507: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.507: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.507: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=209) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.507: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.507: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.517: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.517: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.517: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.517: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.517: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.520: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.520: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.520: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.520: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.521: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.521: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.521: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.521: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.521: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.523: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:57:00.523: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  on AP 84:78:ac:c0:c7:90, slot 1, interface = 13, QOS = 0
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.523: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.523: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.523: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.523: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:57:00.523: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITDONE (message 5 - group), replay counter 00.00.00.00.00.00.00.02
*spamApTask5: Aug 01 10:57:00.524: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:57:00.524: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:57:01.704: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:57:01.704: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:01.746: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:01.746: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:01.746: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:57:08.506: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x84:78:ac:c0:c7:90
*apfLbsTask: Aug 01 10:57:08.506: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:1 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:57:08.506: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:57:08.506: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:57:08.506: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:57:08.506: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:57:08.506: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:57:08.506: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_7: Aug 01 10:57:19.832: 74:de:2b:31:55:22 Association received from mobile on AP 84:78:ac:c0:c7:90
*apfMsConnTask_7: Aug 01 10:57:19.832: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_7: Aug 01 10:57:19.832: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_7: Aug 01 10:57:19.832: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:19.832: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:19.832: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*pemReceiveTask: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1for this client
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:c7:90 from Associated to Associated
*apfMsConnTask_7: Aug 01 10:57:19.833: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_7: Aug 01 10:57:19.834: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 84:78:ac:c0:c7:90 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_7: Aug 01 10:57:19.834: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:c7:90 from Associated to Associated
*dot1xMsgTask: Aug 01 10:57:19.835: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:57:19.835: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:57:19.835: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.843: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.843: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.843: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.846: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.846: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.847: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.847: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.847: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.847: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.847: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.849: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.849: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=5) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.849: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 5 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.849: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 5)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.850: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.850: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 5, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.850: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.866: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.866: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=6) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.866: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 6)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.867: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.868: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 6, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.868: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.882: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.882: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=7) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.882: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 7)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.884: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.884: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 7, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.884: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.898: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.898: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=8) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.898: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 8)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.899: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.899: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 8, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.899: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 8)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.915: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.916: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=8) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.916: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.916: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.926: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.926: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.926: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.926: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.926: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.930: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.932: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:57:19.932: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.932: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.932: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.932: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.933: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:57:19.933: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask5: Aug 01 10:57:19.933: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:57:19.934: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*osapiBsnTimer: Aug 01 10:57:21.104: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:57:21.104: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*osapiBsnTimer: Aug 01 10:57:22.106: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:57:22.106: 74:de:2b:31:55:22 Retransmit 2 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:22.373: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:22.373: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:22.373: 74:de:2b:31:55:22 EAPOL Key message with invalid authenticator replay counter
                                       got      00 00 00 00 00 00 00 03
        expected 00 00 00 00 00 00 00 04
*Dot1x_NW_MsgTask_2: Aug 01 10:57:22.391: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:22.391: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:22.391: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:57:24.509: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x84:78:ac:c0:c7:90
*apfLbsTask: Aug 01 10:57:24.509: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:1 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:57:24.509: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:57:24.509: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:57:24.509: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:57:24.509: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:57:24.509: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:57:24.509: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 Association received from mobile on AP 84:78:ac:c0:c7:90
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_7: Aug 01 10:57:34.803: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*pemReceiveTask: Aug 01 10:57:34.804: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1for this client
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:c7:90 from Associated to Associated
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 84:78:ac:c0:c7:90 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_7: Aug 01 10:57:34.804: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:c7:90 from Associated to Associated
*dot1xMsgTask: Aug 01 10:57:34.807: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:57:34.807: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:57:34.807: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.814: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.814: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.814: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.816: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.816: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.820: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.821: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.821: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.821: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.821: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.823: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.823: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=46) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.823: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 46 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.823: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 46)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.827: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.827: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 46, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.827: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.836: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.836: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=47) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.836: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 47)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.846: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.846: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 47, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.846: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.852: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.852: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=48) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.852: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 48)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.857: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.857: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 48, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.857: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.867: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.867: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=49) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.867: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 49)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.868: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.869: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 49, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.869: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.884: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 49)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.885: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.885: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.885: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=49) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.885: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.885: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.896: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.896: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.896: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.896: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.896: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
                                    state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.899: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.899: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.900: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.900: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.900: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.900: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.900: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:c7:90 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.900: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.900: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.902: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:57:34.902: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  IPv4 ACL ID = 255, IPv6 ACL ID =
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.902: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.903: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.903: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.903: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.903: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:57:34.904: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*spamApTask5: Aug 01 10:57:34.920: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.937: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.937: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:57:34.937: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfLbsTask: Aug 01 10:57:40.505: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x84:78:ac:c0:c7:90
*apfLbsTask: Aug 01 10:57:40.505: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:1 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:57:40.505: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:57:40.505: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:57:40.506: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:57:40.506: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:57:40.506: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:57:40.506: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*apfMsConnTask_0: Aug 01 10:58:42.882: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 Reassociation received from mobile on AP 84:78:ac:c0:c9:a0
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1709)
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1876)
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 Applying site-specific Local Bridging override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 Applying Local Bridging Interface Policy for station 74:de:2b:31:55:22 - vlan 336, interface id 14, interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 Applying site-specific override for station 74:de:2b:31:55:22 - vapId 1, site 'Clinical', interface 'rumcwireless'
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_1: Aug 01 10:59:07.350: 74:de:2b:31:55:22 STA - rates (6): 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 Processing WPA IE type 221, length 22 for mobile 74:de:2b:31:55:22
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 Setting active key cache index 0 ---> 8
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 unsetting PmkIdValidatedByAp
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Deleted mobile LWAPP rule on AP [84:78:ac:c0:c7:90]
*pemReceiveTask: Aug 01 10:59:07.351: 74:de:2b:31:55:22 10.171.38.171 Removed NPU entry.
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 Updated location for station old AP 84:78:ac:c0:c7:90-1, new AP 84:78:ac:c0:c9:a0-1
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 apfMsRunStateDec
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 apfMs1xStateDec
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 10.171.38.171 START (0) Initializing policy
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 10.171.38.171 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 10.171.38.171 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) DHCP Not required on AP 84:78:ac:c0:c9:a0 vapId 1 apVapId 1for this client
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:c9:a0 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:c9:a0 from Associated to Associated
*apfMsConnTask_1: Aug 01 10:59:07.351: 74:de:2b:31:55:22 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_1: Aug 01 10:59:07.352: 74:de:2b:31:55:22 Sending Assoc Response to station on BSSID 84:78:ac:c0:c9:a0 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_1: Aug 01 10:59:07.352: 74:de:2b:31:55:22 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 74:de:2b:31:55:22 on AP 84:78:ac:c0:c9:a0 from Associated to Associated
*dot1xMsgTask: Aug 01 10:59:07.353: 74:de:2b:31:55:22 Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 01 10:59:07.353: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*dot1xMsgTask: Aug 01 10:59:07.353: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.357: 74:de:2b:31:55:22 Received EAPOL START from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.357: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Connecting state
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.357: 74:de:2b:31:55:22 Sending EAP-Request/Identity to mobile 74:de:2b:31:55:22 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.359: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.359: 74:de:2b:31:55:22 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.360: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.360: 74:de:2b:31:55:22 Received Identity Response (count=2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.360: 74:de:2b:31:55:22 EAP State update from Connecting to Authenticating for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.360: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticating state
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.360: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.363: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.363: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=116) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.363: 74:de:2b:31:55:22 WARNING: updated EAP-Identifier 2 ===> 116 for STA 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.363: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 116)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.364: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.364: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 116, EAP Type 3)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.364: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.373: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.373: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=117) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.373: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 117)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.375: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.375: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 117, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.375: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.389: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.389: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=118) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.389: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 118)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.391: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.391: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 118, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.391: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.404: 74:de:2b:31:55:22 Processing Access-Challenge for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.404: 74:de:2b:31:55:22 Entering Backend Auth Req state (id=119) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.404: 74:de:2b:31:55:22 Sending EAP Request from AAA to mobile 74:de:2b:31:55:22 (EAP Id 119)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.405: 74:de:2b:31:55:22 Received EAPOL EAPPKT from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.405: 74:de:2b:31:55:22 Received EAP Response from mobile 74:de:2b:31:55:22 (EAP Id 119, EAP Type 25)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.405: 74:de:2b:31:55:22 Entering Backend Auth Response state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.421: 74:de:2b:31:55:22 Processing Access-Accept for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.421: 74:de:2b:31:55:22 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.421: 74:de:2b:31:55:22 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.421: 74:de:2b:31:55:22 Setting re-auth timeout to 65535 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Station 74:de:2b:31:55:22 setting dot1x reauth timeout = 65535
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Creating a PKC PMKID Cache entry for station 74:de:2b:31:55:22 (RSN 0)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Sending EAP-Success to mobile 74:de:2b:31:55:22 (EAP Id 119)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Starting key exchange to mobile 74:de:2b:31:55:22, data packets will be dropped
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Entering Backend Auth Success state (id=119) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 Received Auth Success while in Authenticating state for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.422: 74:de:2b:31:55:22 dot1x - moving mobile 74:de:2b:31:55:22 into Authenticated state
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.432: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.432: 74:de:2b:31:55:22 Received EAPOL-key in PTK_START state (message 2) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.432: 74:de:2b:31:55:22 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.432: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.432: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 10.171.38.171 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) DHCP Not required on AP 84:78:ac:c0:c9:a0 vapId 1 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 84:78:ac:c0:c9:a0 vapId 1 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.437: 74:de:2b:31:55:22 10.171.38.171 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.439: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Reached PLUMBFASTPATH: from line 5414
*Dot1x_N: Aug 01 10:59:07.439: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Adding Fast Path rule
  on AP 84:78:ac:c0:c9:a0, slot 1, interface = 13, QOS = 0
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.439: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 15206  Local Bridging Vlan = 336, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.439: 74:de:2b:31:55:22 10.171.38.171 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.439: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.440: 74:de:2b:31:55:22 Key exchange done, data packets from mobile 74:de:2b:31:55:22 should be forwarded shortly
*Dot1x_NW_MsgTask_2: Aug 01 10:59:07.440: 74:de:2b:31:55:22 Sending EAPOL-Key Message to mobile 74:de:2b:31:55:22
*spamApTask4: Aug 01 10:59:07.441: 74:de:2b:31:55:22 Sent EAPOL-Key M5 for mobile 74:de:2b:31:55:22
*pemReceiveTask: Aug 01 10:59:07.442: 74:de:2b:31:55:22 10.171.38.171 Added NPU entry of type 1, dtlFlags 0x0
*apfLbsTask: Aug 01 10:59:08.505: 74:de:2b:31:55:22 Copy AP LOCP - mode:0 slotId:1, apMac 0x84:78:ac:c0:c9:a0
*apfLbsTask: Aug 01 10:59:08.505: 74:de:2b:31:55:22 Copy WLAN LOCP EssIndex:1 aid:14 ssid:RUMCWireless
*apfLbsTask: Aug 01 10:59:08.505: 74:de:2b:31:55:22 Copy Security LOCP ecypher:0x1 ptype:0x1, p:0x0, eaptype:0x2 w:0x1 aalg:0x0, PMState:        RUN
*apfLbsTask: Aug 01 10:59:08.505: 74:de:2b:31:55:22 Copy 802.11 LOCP a:0x0 b:0x0 c:0x0 d:0x0 e:0x0 protocol2:0x1 statuscode 0, reasoncode 1, status 3
*apfLbsTask: Aug 01 10:59:08.505: 74:de:2b:31:55:22 Copy Username LOCP : RUSH\mkl09mc608
*apfLbsTask: Aug 01 10:59:08.505: 74:de:2b:31:55:22 Copy IP LOCP: 0xaab26ab
*apfLbsTask: Aug 01 10:59:08.505: 74:de:2b:31:55:22 Copy CCX LOCP 5
*apfLbsTask: Aug 01 10:59:08.505: 74:de:2b:31:55:22 Copy MobilityData LOCP status:1, anchorip:0x0
*osapiBsnTimer: Aug 01 10:59:08.506: 74:de:2b:31:55:22 802.1x 'timeoutEvt' Timer expired for station 74:de:2b:31:55:22 and for message = M5
*dot1xMsgTask: Aug 01 10:59:08.506: 74:de:2b:31:55:22 Retransmit 1 of EAPOL-Key M5 (length 131) for mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:08.511: 74:de:2b:31:55:22 Received EAPOL-Key from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:08.511: 74:de:2b:31:55:22 Received EAPOL-key in REKEYNEGOTIATING state (message 6) from mobile 74:de:2b:31:55:22
*Dot1x_NW_MsgTask_2: Aug 01 10:59:08.511: 74:de:2b:31:55:22 Stopping retransmission timer for mobile 74:de:2b:31:55:22
*apfMsConnTask_7: Aug 01 11:00:46.029: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_2: Aug 01 11:04:05.302: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_2: Aug 01 11:04:09.740: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_6: Aug 01 11:10:51.462: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_0: Aug 01 11:10:54.924: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_0: Aug 01 11:10:55.119: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_7: Aug 01 11:10:57.713: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_4: Aug 01 11:11:13.738: Association request from the P2P Client Process P2P Ie and Upadte CB
Bronze
Horrible roaming and connection dropping from client
i have checked the debugs, and some times it goes to association stage, and other times it goes to re-association.
-do you face it everytime the client roams? or it might work in certain places?
-other clients roam fine?
Hall of Fame Super Silver
Could be a lot of things.... Like Yahya mentioned, you need to provide more info so we understand if its localized or not.  Alos provide the show wlan .  On the client side, make sure you don't mess around with the defaults card settings except for maybe disabling power save.  You might also want to see what the roaming aggressiveness is set to.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Community Member
Hello guys, thank you for the responses.
My next to do for the wireless carts is to have them set the security/encryption to WPA2/AES.  Right now, it is all over the board, no standard.  WPA/TKIP, WPA/AES, WPA2/TKIP.
Yahya,
to answer your questions:
- I have it at times when the client roams, sometimes I can be sitting in one stationary area with the the cart and all of a sudden the wireless nic shows a red symbol and then it re-associates itself.
- other clients roam just fine.
Scott,
Here is the the output of the wlan:
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... RUMCWireless
Network Name (SSID).............................. RUMCWireless
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 165
Exclusionlist.................................... Disabled
Session Timeout.................................. 65535 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ rumcwireless
--More-- or (q)uit
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11a and 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
--More-- or (q)uit
   Authentication................................ 10.74.10.51 1812
   Authentication................................ 10.74.137.25 1812
   Accounting.................................... 10.74.10.51 1813
   Accounting.................................... 10.74.137.25 1813
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      WPA2 (RSN IE).............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
--More-- or (q)uit
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Enabled
   FlexConnect Local Switching................... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 0
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
--More-- or (q)uit
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
1           172.19.3.13           Up
802.11u........................................ Disabled
  Access Network type............................ Not configured
  Network Authentication type.................... Not configured
  Internet service............................... Disabled
  HESSID......................................... 00:00:00:00:00:00
Hotspot 2.0.................................... Disabled
  WAN Metrics configuration
    Link status.................................. 0
    Link symmetry................................ 0
--More-- or (q)uit
    Downlink speed............................... 0
    Uplink speed................................. 0
Mobility Services Advertisement Protocol....... Disabled
534
