10-25-2002 08:39 AM - edited 07-04-2021 11:29 PM
Hello, I have not devices to test and i have a question: Can I use two devices configured as repeaters in a hot-standby redundant configuration. I think that's only possible if the standby one monitors the main device via Air-interface (i think that's right). The second part: Can it work if they both are connected to the same antenna via a splitter?
10-31-2002 02:29 PM
I understand from these URLs that you can backup only a Wired access point and not the repeater itself. I could not locate any document talking about hot standby for the repeater units.
11-01-2002 03:13 PM
Nope..The Hot standby unit will moniter the "radio interface and ethernet interface" of primary..So the moment you loose one of them, the standby unit will takeover.
Now in case of repeater, the eth port is disabled already..so repeaters can't be used for hot standby function.
