Community Member
How to change a 1:1 to a N+1 cluster
Hi all,
My customer has a 1:1 cluster, now I want to change the setup for OEAP600, this means I have to set the NAT Address on the Management Interface.This seems not be possible in a 1:1 Cluster. -> I have to break the cluster, set the NAT Address and make it a cluster again.
Instead of building the cluster again I would like to make it  to a N+1 failover. Yes, I loose AP and Client SSO but will have other advantages.
What do I need to do if I want to make a N+1 from a 1:1 Cluster?
What happens with the actuall config on the secondary after disabling SSO?
Willem
1 REPLY
Hall of Fame Super Silver
Re: How to change a 1:1 to a N+1 cluster
Easy... Sort of. You need to disable AP SSO and then what I would do is default the redundancy IP on the primary and factory default the on that was the HA pair. Then configure the HA pair as a normal WLC and setup the access points high availability
http://www.cisco.com/en/US/docs/wireless/technology/hi_avail/N1_High_Availability_Deployment_Guide.pdf
-Scott
133
