How to change the connection timeout value on a HWIC-3G-CDMA interface??
How do you change the timeout value on the HWIC-3G-CDMA interface card? The connection times out or disconnects after a minute or two when there is no traffic or activity going on. Is there a way to change the timeout value so it stays connected longer?
Silver
Re: How to change the connection timeout value on a HWIC-3G-CDMA
The 3G wireless HWIC provides the software functionality Automatic teardown, After a configurable timeout value, the 3G wireless HWIC automatically tears down a connection if there has been no activity.
'dialer idle-timeout ###' should keep the connection open until the specified time.
402
