How to configure session time-out on Cisco autonomous AP?
Dear Team,
Can you provide command for configuring session timeout on Cisco autonomous AP (1242 AP).
Harsha
Hi Harsha,
If it is 802.1X enable WLAN, you can try below command under radio interfaces (ie int d0 & int d1).
dot1x client-timeout x
If you want to set re-auth time, then you can use below. If you use "server" keyword then it will use the value send by your RADIUS server.
dot1x reauth-period { seconds | server }
Here is the command reference guide.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-2_8_JA/command/reference/b1228cr/bcrmain.html#wp2454010
Rasika
**** Pls rate all useful responses ****
Hi Harsha,
Rasika
Thanks Rasika
I'm having a (possible) problem with timeout and thanks for the command you gave. How would one see the current timeout status? I tried:
'sh dot1x int Dot11Radio 0 statistics' but it never gave anything
