How to deploy multiple VPN gateways on WLC VPN Passthrough
Hi all,
I got several VPN gateways(servers) behind my WLC 4402. I need configure their IP addresses in WLAN Layer3 security section VPN passthrough. But WLC permit to enter only one IP address of VPN gateway. What to do?
Thanks for your answers
Silver
Re: How to deploy multiple VPN gateways on WLC VPN Passthrough
In WLC, you can configure only one VPN passthrough Gateway address. Multiple addresses cannot be configured
What I've seen done in the past is configuring the WLAN for OPEN access, but then applying an ACL on the interface that only allows traffic to/from the VPN gateway(s). This may work for your needs.
Thanks for your advice.
Which protocols should i permit in ACL?
Is IP50,IP51 and UDP500 is enoughf?
145
