How to enable EAP-FAST & LEAP (with & without CCKM) with WDS and local authenticator
I have a configuration AP & WDS (with AP):
#show version
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
cisco AIR-AP1142N-R-K9     (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
Product/Model Number                 : AIR-AP1142N-R-K9
################## WDS (with AP) ########################
aaa new-model
aaa group server radius SRV-AP
server 192.168.255.254 auth-port 1812 acct-port 1813
aaa group server radius SRV-CLIENT
server 10.0.0.50 auth-port 1645 acct-port 1646
aaa authentication login default local
aaa authentication login AAA-CLIENT-CCKM group SRV-AP
aaa authentication login AAA-AP group SRV-AP
aaa authentication login AAA-CLIENT group SRV-CLIENT
aaa authorization exec default local
dot11 ssid CCKM-ROAMING
   vlan 101
   authentication open eap AAA-CLIENT-CCKM
   authentication network-eap AAA-CLIENT-CCKM
   authentication key-management cckm
   mbssid guest-mode
dot11 ssid WPA-ENTERPRISE
   vlan 102
   authentication key-management wpa
   mbssid guest-mode
dot11 ssid WPA-PSK
   vlan 103
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 0103140D551F031D32
dot11 ssid WPA-ROAMING
   vlan 104
   mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 101 mode ciphers tkip
encryption vlan 102 mode ciphers aes-ccm tkip
encryption vlan 103 mode ciphers aes-ccm tkip
encryption vlan 104 mode ciphers aes-ccm tkip
ssid CCKM-ROAMING
ssid WPA-ENTERPRISE
ssid WPA-PSK
ssid WPA-ROAMING
antenna gain 0
mbssid
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.101
encapsulation dot1Q 101
no ip route-cache
bridge-group 101
bridge-group 101 subscriber-loop-control
bridge-group 101 block-unknown-source
no bridge-group 101 source-learning
no bridge-group 101 unicast-flooding
bridge-group 101 spanning-disabled
interface Dot11Radio0.102
encapsulation dot1Q 102
no ip route-cache
bridge-group 101
interface Dot11Radio0.103
encapsulation dot1Q 103
no ip route-cache
bridge-group 101
interface Dot11Radio0.104
encapsulation dot1Q 104
no ip route-cache
bridge-group 101
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.33
encapsulation dot1Q 33
no ip route-cache
bridge-group 1
interface GigabitEthernet0.101
no ip route-cache
bridge-group 101
interface GigabitEthernet0.4094
encapsulation dot1Q 4094 native
no ip route-cache
bridge-group 255
no bridge-group 255 source-learning
bridge-group 255 spanning-disabled
interface BVI1
ip address 172.20.254.33 255.255.255.240
no ip route-cache
ip default-gateway 172.20.254.46
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.255.254 auth-port 1812 acct-port 1813 key 7 120B04131B1E1F
radius-server host 10.0.0.50 auth-port 1645 acct-port 1646 key 7 06140E25455B1A
radius-server vsa send accounting
bridge 1 route ip
wlccp authentication-server infrastructure AAA-AP
wlccp authentication-server client any AAA-CLIENT
  ssid CCKM-ROAMING
  ssid WPA-ENTERPRISE
wlccp wds priority 254 interface BVI1
############################# AP ##################################
aaa new-model
   vlan 101
   mbssid guest-mode
   vlan 102
   mbssid guest-mode
dot11 ssid WPA-PSK
   vlan 103
   authentication open
   mbssid guest-mode
   vlan 104
   mbssid guest-mode
no ip address
no ip route-cache
ssid CCKM-ROAMING
ssid WPA-ENTERPRISE
ssid WPA-PSK
ssid WPA-ROAMING
antenna gain 0
mbssid
station-role root
bridge-group 1
no ip route-cache
bridge-group 101
no ip route-cache
bridge-group 101
no ip route-cache
bridge-group 101
no ip route-cache
bridge-group 101
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 101
no ip route-cache
bridge-group 255
interface BVI1
ip address 172.20.254.34 255.255.255.240
no ip route-cache
radius-server host 192.168.255.254 auth-port 1812 acct-port 1813 key 7 04490A0206345F
radius-server host 10.0.0.50 auth-port 1645 acct-port 1646 key 7 001612020D4E18
bridge 1 route ip
wlccp ap username ap password 7 050A16
wlccp ap wds ip address 172.20.254.33
######################## 192.168.255.254 - Cisco local authenticator ##########################
radius-server local
eapfast server-key primary 7 B262265DFAF35849CA6EE02C844AE00DDA
nas 172.20.254.33 key 7 111B18011E0718
nas 172.20.254.34 key 7 03165A0F0F1A32
user ap nthash 7 1545295A5D7F0E720D1562764522322625007B7C707756513A3401080703717705
########################## 10.0.0.50 - Microsoft NAS #####################################
<standart configutration>
When I try to connect to WPA-ENTERPRISE or WPA-PSK - connected, but when I try to connect ot CCKM-ROAMING or WPA-ROAMING using EAP-FAST or LEAP (with or without CCKM) - connection failed.
Notice:
In the current configuration, if client use LEAP (without CCKM) and AP work without WDS - WPA-ROAMING is worked correctly. But
if client use LEAP (without CCKM) and AP work with WDS - WPA-ROAMING is not working.
when your client connects to CCKM-ROAMING, what credentials are being used?
Per your config, CCKM-ROAMING and WPA-ROAMING use login method AAA-CLIENT-CCKM, which points at server group SRV-AP
While WPA-Enterprise points to login method AAA-CLIENT, which points at server gropu SRV-CLIENT
From what I can see of the local radius server config, when the client connects to CCKM-ROAMING or WPA-ROAMING they would have to use username ap and password ap.
Now, if you change the methods to point to SRV-CLIENT instead of the AP method, they should be able to use what ever username/password that 10.0.0.50 allows.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Yes. When client connect to CCKM-ROAMING or WPA-ROAMING they use username/password ap/*** (from 192.168.255.254 radius server, this for test only reasons), because clients use EAP-FAST or LEAP. They don't use Microsoft RADIUS (10.0.0.50), because it not support this protocols. And AP Infrastructure authentication use same username/password: ap/***.
..but don't work((
what client is being used?  can you post screen shots of the CCKM-ROAMING config?
Re: How to enable EAP-FAST & LEAP (with & without CCKM) with WDS
CCKM-ROAMING used by Motorola MC9190.
Wi-Fi configuration:
1. Profile Name: CCKM-ROAMING
ESSID: CCKM-ROAMING
2. Operating Mode: Infrastructure
Country: Allow Any Country
3. Security Mode: WPA - Enterprise
Authentication Type: EAP-FAST
4. CCX Options: CCKM Enabled
5. Tunnel Authentication Type: MS CHAP v2
Provide User Certificate: Disabled
6. Installed Server Certificates:
Validate Server Certificate: Disabled
7. Enter User Name: ap
Enter Domain:
8. Enter Password: ***
Advanced ID: Disabled
9. Prompt for Login: At Connect - Enabled, On Resume - Disabled, At Time - Disabled.
10. Encryption Type: TKIP
11. IPv4 Address Type: Enabled all "Obtain" features (IP, DNS, WINS)
12. Transmit Power: Automatic
13. Battery Usage Mode: Fast Power Save.
Debug:
AP1#
Mar 12 18:23:07: %DOT11-7-AUTH_FAILED: Station 0023.68xx.xxx Authentication failed
AP1#
Mar 12 18:23:14: %DOT11-7-AUTH_FAILED: Station 0023.68xx.xxxx Authentication failed
AP1#
on the AP 192.168.255.254 can you run:
debug radius local-server client
debug radius local-server error
debug radius local-server eapfast events
capture the output and attach so we can see what the AP thinks is going on.
192.168.255.254 - is a router Cisco 2851 and "debug radius local-server ..." is not present in CLI ("debug radius ..." only, but any messages is not displayed)
Cisco2851#show radius local-server statistics
Successes              : 0           Unknown usernames      : 0
Client blocks          : 0           Invalid passwords      : 0
Unknown NAS            : 0           Invalid packet from NAS: 0
NAS : 172.20.254.33
Corrupted packet       : 0           Unknown RADIUS message : 0
No username attribute  : 0           Missing auth attribute : 0
Shared key mismatch    : 0           Invalid state attribute: 0
Unknown EAP message    : 0           Unknown EAP auth type  : 0
Auto provision success : 0           Auto provision failure : 0
PAC refresh            : 0           Invalid PAC received   : 0
NAS : 172.20.254.34
Maximum number of configurable users: 50, current user count: 1
Username                  Successes  Failures  Blocks
ap                                0         0       0
Even there is no attempt of authentication
Configure the local authenticator on WDS and AP to authenticate clients on WDS server, but so anything and did not change - there is no attempt of authentication. Debug "debug radius local-server ..." is empty.
Anybody never set up EAP-FAST or LEAP?!
Bronze
Post the following outputs from the WDS master.  Do you see both the WDS and secondary AP "Registered"?
#show wlccp wds ap
You can focus on your LEAP authentication between AP's and get that squared away before resolving the "client" authentication.
Here's a step-by-step I have put together to get the WDS and subordinant AP paired together using LEAP from the WDS master local RADIUS.
WDS Master
Turn on AAA feature set
1. aaa new-model
Create "Infrastructure" server group (We will point this to ourselves for local authentication)
2. aaa group server radius Infrastructure
a. server auth-port 1812 acct-port 1813
Create "Client" server group for authenticating clients (Pointing to Microsoft NPS server in this case)
3. aaa group server radius Client
Set AAA login methods to user groups created above
4. aaa authentication login method_Infrastructure group Infrastructure (using Infrastructur server group)
5. aaa authentication login method_Client group Client (using Client srever group)
Set SSID EAP authenticaiton
6. dot11 ssid
a. authentication open eap method_Client (method defined above)
b. authentication network-eap method_Client
c. authentication key-management wpa
d. guest-mode (if wanting to broadcast, good for testing)
Define WDS Master as local authenticator for infrastructure AP authentication
7. radius-server local
Remove unused authentication types as infrastructure will be using LEAP
a. no authentication eapfast
b. no authentication mac
Define WDS Infrastructure APs and specify their shared key, including local AP
c. nas key 0
d. nas key 0
Create username/password for LEAP WDS between APs
user password
Define AAA server hosts (in this case we need to define ourselves as the local authenticator and the NPS server for client authentication)
8. radius-server host auth-port 1812 acct-port 1813 key 0
9. radius-server host auth-port 1812 acct-port 1813 key 0
Format for both server hosts
a. radius-server attribute 32 include-in-access-req format %h
Turn on WDS functionality at Master
10. wlccp wds priority 254 interface BVI1
Add wlccp config, create user/pass from radius-server above, then define authentication server for infrastructure and client
11. wlccp ap username password
12. wlccp authentication-server infrastructure method_Infrastructure
13. wlccp authentication-server client eap method_Client
Specify SSID to apply authentication to clients on
a. ssid
WDS Subordinant
1. aaa new-model
2. Create Identical SSID config as at the Master
Add RADIUS host of the AP WDS Master for infrastructure and client authentication
3. radius-server host auth-port 1812 acct-port 1813 key 0
4. radius-server attribute 32 include-in-access-req format %h
Add WDS functionality and point to master WDS AP
5. wlccp ap username password
Master AP should now show itself and infrastructure AP "REGISTERED"
#show wlccp wds ap
Thanks! I already reconfigure Wi-Fi network. Now local authenicatior is a WDS-with-AP (not Cisco2851).
Test results:
1. All work (all SSID with: CCKM, WPA, LEAP), exclude EAP-FAST.
Debug from WDS-with-AP local RADIUS, when clients attempt to connect with EAP-FAST:
Mar 15 10:21:15: RADSRV: EAP NAK received - starting EAP-FAST
Mar 15 10:21:15: RADSRV EAP-FAST: Add teap client 0023.68xx.xxxx
Mar 15 10:21:15: RADSRV EAP-FAST:  Sending TEAP start
WDS#
Mar 15 10:21:22: RADSRV: EAP NAK received - starting EAP-FAST
Mar 15 10:21:22: RADSRV EAP-FAST: Add teap client 0023.68xx.xxxx
Mar 15 10:21:22: RADSRV EAP-FAST:  Sending TEAP start
WDS#
New configuration:
#################### WDS (with AP) ###############################
aaa group server radius SRV-LOCAL-AUTH
server 172.20.254.33 auth-port 1812 acct-port 1813
aaa group server radius SRV-REMOTE-AUTH
aaa authentication login AAA-CLIENT-CCKM group SRV-LOCAL-AUTH
aaa authentication login AAA-AP group SRV-LOCAL-AUTH
aaa authentication login AAA-CLIENT group SRV-REMOTE-AUTH
dot11 ssid UEG-CCKM-ROAMING
   vlan 101
   mbssid guest-mode
dot11 ssid UEG-WPA-ENTERPRISE
   vlan 102
   mbssid guest-mode
dot11 ssid UEG-WPA-PSK
   vlan 103
   authentication open
   mbssid guest-mode
dot11 ssid UEG-WPA-ROAMING
   vlan 104
   mbssid guest-mode
no ip address
no ip route-cache
ssid UEG-WPA-PSK
interface BVI1
no ip route-cache
radius-server local
  nas 172.20.254.33 key 7 1405130F051139
  nas 172.20.254.34 key 7 120B04131B1E1F
  user cisco nthash 7 15472854547A0D757B126601365F402625040C0C03702A573D410A0B06760B7406
  user ap nthash 7 0758031A175C3C5332345C58520F0F010C65170630244E512374010803042D2149
radius-server host 172.20.254.33 auth-port 1812 acct-port 1813 key 7 105C081D0C0201
bridge 1 route ip
wlccp authentication-server client any AAA-CLIENT-CCKM
   vlan 101
   mbssid guest-mode
   vlan 102
   mbssid guest-mode
   vlan 103
   authentication open
   mbssid guest-mode
   vlan 104
   mbssid guest-mode
no ip address
no ip route-cache
ssid UEG-WPA-PSK
interface BVI1
no ip route-cache
radius-server host 172.20.254.33 auth-port 1812 acct-port 1813 key 7 06140E25455B1A
bridge 1 route ip
As a result of 2 questions:
1. Why Cisco2851 is not work correct with LEAP/EAP-FAST?!
2. Why EAP-FAST doesn't work at this config?
How to enable EAP-FAST?!
1873
