How to fix Channel issue
I am working on Cisco 1230 and 1240 series of access points with IOS
Version 12.3(8) JA2 and these access points showing channel 1 to
channel 13 but most of the chipsets doesn't support channel no 12,13.
How do i Negotiate these channel issue from channel 1 to 13, to
channel 1 to 11 in the cisco aironet devices.
what are the commands/options that we need to set in the devices so
that the won't propagate channel 12,13 any more.
looking forward for the advices at the earliest
Srihari
Green
Re: How to fix Channel issue
Check the country code of the AP. Change it to a country that doesn't use channels 12 & 13 (like the USA).
Good Luck
Scott
Hi Scott, We actually tried the "world-mode dot11d country GB both" commands under the dot11radio0 interfaces, but it does not seem to have any impact.. Great britain i guess uses only channels 1-11.
conf t
inter dot 0
channel least-congested 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462
or by gui:
network interface > settings. find the "Default Radio Channel Channel:" select: least-congested from the drop down menu. Mark the channel 1-11 (use ctrl+mouse)
Kind regards
Finn
178
