how to remove HA from MSE CLI
vinodjad1234
Level 2
Level 2
I was checking if we have any command remove HA  from MSE cli. we can remove from prime however do we have any option from MSE cli to remove HA directly ?
ali aqrabawi
Level 3
Level 3
if you want to check the commands available on the MSE go to /MSE/bin directory and check the available commands there , you may find a command to do that there ,
to check the command details
[MSE]#man Command
and
[MSE]#command --usage
ali aqrabawi
Level 3
Level 3
[MSE]#man Command
and
Hi Ali,
Thanks for your reply.
