03-24-2018 09:39 PM - edited 07-05-2021 08:25 AM
instead of <enter> the console interprets signal as smiling face,other characters also not correspond to the keyboard,
how to fix?
03-24-2018 09:59 PM
03-24-2018 10:48 PM
this AP is CAP2702I, not sure that it has factory reset option...
default value 9600 does not work at all, which machines are suggested?
03-24-2018 10:05 PM
03-24-2018 10:50 PM
the problem is that shown above picture is in ROMMON mode: instead of <enter> - smiling face and characters on console not relate to keyboard...
03-24-2018 11:19 PM
03-25-2018 01:28 AM
Could flow control possibly be causing this too?
Ric
03-25-2018 03:43 AM
03-28-2018 01:50 AM
change the baud settings of console terminal /one notch at a time/ did not help
I also tried different console software to connect to this access point.
Problem still there, only considering to bring it back to supplier. Will Cisco support such case to restore or exchange to another AP?!
03-28-2018 06:59 AM
