How to set speed and duplex for APs
Dirk Woellhaf
I'm using two 4402 running the following versions:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 5.2.157.0
RTOS Version..................................... 5.2.157.0
Bootloader Version............................... 4.2.112.0
Emergency Image Version.......................... 5.2.157.0
Build Type....................................... DATA + WPS
Where can I set the speed/duplex mode for the APs?
In earlier versiones there was a "config ap ethernet"-command.
Any ideas?
Regards Dirk
regards, Dirk (Please rate if helpful)
6 Replies 6
tsennett
This works in 5.0.148.2
config AP ethernet duplex (x) speed (x) (AP NAME)
Thanks for the reply,
but I don't want to downgrade.
Does anyone know if thess commands are back in the upcoming versions?
regards
Yes ,
These commands are there new versions.
Haven't checked in the version you mentioned,But should not have got removed.
Vinay
Good to know.
Any suggestion when Version 6.x will be available for 440x series?
Regards Dirk
Just to let you all know,
Issue is fixed in version 6.0
regards
regards
