How to stop wireless access to the setup screen ?
I am currently running VxWorks 12.02 in a 350 and 1200 environment. I currently have my AP's sitting on the Native VLAN with 3 other Wireless VLAN's trunked. I can browse from any WVLAN to the AP setup screen. I want to know if there is a simple way to only grant access to the setup screen on the AP only through a wired connection. I rather not set up ACL's on these WVLAN's as this could get messy. I am looking for any other solutions.
Re: How to stop wireless access to the setup screen ?
With out acl I have not seen a way to do it. You can set up the ap to require login access only for the web management. You have to activate the login manager and create a user account. You can also use a radius server.
Hope the helps
I don't know if there is a infrastructure requirement, but you could upgrade them to run IOS (instead of vxworks). IOS, by default, requires a userid and password to log in.
113
