04-04-2006 07:09 AM - edited 07-04-2021 11:53 AM
Does anyone know where I can find documentation on how to upgrade an WLSM?
Many thanks in advance,
Tracey
Solved! Go to Solution.
04-07-2006 10:32 AM
Step 1
Router# hw-module module mod reset
cf:1
Reboots the module from the maintenance partition.
Note It is normal to see messages such as "Press Key" on the module console after entering this command.
Step 2
Router# show module mod
Displays that the maintenance partition for the module has booted.
Step 3
Router# copy tftp: pclc#mod-fs:
Downloads the image.
Step 4
Resets the module.
Step 5
Displays that the application partition for the module has booted.
04-07-2006 10:32 AM
Step 1
cf:1
Step 2
Step 3
Step 4
Resets the module.
Step 5
04-10-2006 01:09 AM
Thanks so much for your help, Dominic.
05-03-2006 02:03 AM
Does anyone know, how to upgrade two redundant WLSMs (Interchassis)? I want to upgrade the standby WLSM and switchover at night, but I don't know, if redundancy works with two different versions.
Any ideas?
