Community Member
HWIC-3G-HSPA Maximun SDU Supported
I using a HWIC-3G-HSPA and getting the following parameters
Data Connection Information
Data Transmitted = 1850711 bytes, Received = 962453 bytes
Profile 1, Packet Session Status = ACTIVE
        IP address =
        Negotiated QOS Parameters:
        Precedence = Normal Priority, Delay = Class 1
        Reliability = Unack GTP, LLC, RLC, Unprotected data
        Peak = 256 kB/sec, Mean = 50000 kB/hr
        Traffic Class = Interactive
        Uplink Max = 11.5Mbps, Guaranteed = Subscribed
        Downlink Max = 11.5Mbps, Guaranteed = Subscribed
        Max SDU size = 10 bytes
        SDU error ratio = 1E-3, BER = 4E-3
1.- Does the SUD parameter related to the Service Provider or  is the value Supported by the Cisco hardware
2.- Does the IOS does IP fragmentation to support the Packet Size of the Mobile Network, cause I see this log msg every time in logging console
"*Dec 31 21:31:11.739: %IP_VFR-4-FRAG_TABLE_OVERFLOW: FastEthernet0/1: the fragment table has reached its maximum threshold 16"
3.- I saw and example of a guy who shows Max SDU a value of 2048 Bytes, does it value fit for the Mobile Networks
Juan M.
