HWIC-AP-AG-A issues in C1841
C1841 256 / 64
12.4(11)XJ or 12.4(11)XW8
Wireless HWIC reports "no valid power levels found"...
Doco says it's a supported module in 1841, but hw configurator does not list it as an option.
If I manually set OFDM power level to max, and force channel scan the intf comes up momentarily but then goes back into err/reset state.
Also, following appears in log.
%ALIGN-3-TRACE: -Traceback= 0x607B7AF8 0x607A6AB4 0x607A8298 0x607A8354 0x6072B058 0x60735CE4 0x60736084 0x0
*Jun 24 21:26:55.475: %ALIGN-3-TRACE: -Traceback= 0x607BE24C 0x607B7958 0x607B7F84 0x607A6AB4 0x607A8298 0x607A8354 0x6072B058 0x607
Module does not do this in 2811 chassis running same code revision.
I am trying a newer X revision of 12.4(11)XW8 to see if it resolves.
Feature set is AdvSecK9
1 REPLY
Re: HWIC-AP-AG-A issues in C1841
Update.
12.4(11)XW8 seems to resolve the issue with the card going into err-disable, and not finding power.
I will post an update after a few days of running.
BD
101
