I am new with Aironet 1131D Device -- Pls Guide me for configuration.
Dear All,
I am new for the device Aironet 1131G . I have tried to configure but Commands are not supported.
The details about the device is given here.
cisco AIR-LAP1131AG-A-K9 (PowerPCElvis) processor (revision A0) with 24566K/81
92K bytes of memory.
Processor board ID FOC12041DM7
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from reload
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1D:E5:54:5A:F4
Part Number : 73-8962-12
PCA Assembly Number : 800-24818-11
PCA Revision Number : B0
PCB Serial Number : FOC12041DM7
Top Assembly Part Number : 800-29144-02
Top Assembly Serial Number : FOC12041DM7
Top Revision Number : A0
Product/Model Number : AIR-LAP1131AG-A-K9
Pls suggest me for the configuration.......
1 ACCEPTED SOLUTION
Re: I am new with Aironet 1131D Device -- Pls Guide me for confi
Hi Dipesh,
You can get the file from Cisco site. Once you are authorized CCO username and password whether you have access right to download software. Here is how you can navigate on website.
Login to cisco website home page > support > Download Software > wireless software > Login with CCO username and password > select access point folder >Cisco Aironet 1130AG Series > IOS software >12.4(10b)ja3 >select wireless lan hyper link.
Download it after accepting cisco agreement.
The file full name is : c1130-k9w7-tar.124-10b.JA3.tar
And you need to rename it to :
c1130-k9w7-tar.defaut.
Now follow my last email to load the file on AP using Tftp server.
Remember keep ethernet connection between AP and laptop/pc.
AP--------PC/Laptop (10.0.0.3/255.255.255.0)
- Try to bring AP to AP: mode By breaking boot sequence. Once AP fall in this mode you will see on console AP:
- Try mode button steps ie keep mode button press and reboot AP , keep mode button hold till 30 sec and you will see status light will turn to red.
- Release mode button and if everything connected well you will see file transfer from Tftp server to AP.
Note: Keep Tftp runnning on your pc/laptop. Tftp will aquire pc ip address.
Firmware need to be in root directory of tftp server.
You can watch the file transfer on console connection.
Kunal
If you still stuck then open Case with TAC team.
You can co-odinate with me @ 9873184440 for any help
Hi Dipesh,
Hope you are doing good.
Looking to the AP(1131) version it look like LWAPP device (which work with controller )and hence your IOS command for autonomous AP are not working for you.
Work around is to convert the AP into autonomous mode.
- You will need TFTP server for this conversation .please use the link to download one.
http://tftpd32.jounin.net/tftpd32_download.html
- YOu will need IOS image for autonomous mode 1131AG AP. Kindly download from http://www.cisco.com
YOu need to have CCO username and password access to download software . YOu will not able to download if you have guest access.
- If guest access take help from reseller to download it for you.
- The image file name will be :
12.4(10b)ja remember file name with extension jx are for lwapp ap. Avoid them .
Steps to downgrade AP.
- Reboot AP and try to break the boot sequence (multiple # sign ) by pressing esc key.
- This will bring AP to colon mode.
Connect ethernet connection between AP and laptop/pc running tftp server configured it with 10.0.0.2 / 24 ip address. No gateway reguire.
- Put the file in root directory of tftp server. You can do so by running tftp server . And click on show directory > explorer. It will take you to the root directory . Put the image file there .
- Rename the image file with default extension.for example : if the image file name is : c1130-k9w7-tar.124-10b.JA.tar then after rename it will look like ...
c1130-k9w7-tar.default
- Verify the file once rename. Sometime in window know file extension are hidden . In that case file not rename properly , so go to explorer > folder option > view > and uncheck the option that say hide know file extension . Then do the renaming of file . Once file rename become unusable.
- One everything all set . Use the mode button beside console port on AP .
- Remove power > Keep press mode button > plug in power source > Keep the mode button press for about 30 second. AFter that status light on AP will turn red. Release the mode button.
- You will see image start loading from tftp server.
- If you find any issue then check connection. check Tftp log view. Check whether firewall not blocking tftp.
- If everything work fine the file will be tranfered AP will reboot itself with new image and work normal as autonomous AP.
Feel free to update me if things work fine for us or else if have any issue.
Kunal
Hi Kunal,
Thanks for help.
Pls can you send me from where I can get this IOS for Autonomuos Mode AP?
Hi Dipesh,
Kunal
Dear Kunal,
I have tried the suggetionn what you have given but It's not working ..... It was not booting from TFTP server.
sh techsupport is given in attahcment.
Dear Krunal,
Thnaks a lot.....
Finally It's working.
Actually Last time I have tried but my TFTP server is not given permission to transmit Data. I had not Configured previously ..but Now it's OK.
Oce again Thanks....
Dipesh Patel
09979226605
Hi Dipesh,
Hope you had wonderful weekend. Thanks for updating about the progress. I'm glad that thinks work for us.
Thanks for choosing Cisco products. You have Great week ahead.
Thanks and regards,
Kunal
595
