i can't connect to internet with VLAN WIRELESS cisco851w
nkila_lna
hello friends,
i have a wireless router 851w configure with 3 vlans and i connect my router with another router ADSL sagem, but i can't connect to internet with 3 vlans.
vlan 1 : 10.0.0.0 255.255.255.0
vlan 2 : 10.0.2.0 255.255.255.0
vlan 3 : 10.0.3.0 255.255.255.0
if i change address of ADSL router to 10.0.0.222 i can connect with vlan 1 but not with vlan 2 and 3.
if i change address of ADSL router to 10.0.2.222 i can connect with vlan 2 but not with vlan 1 and 3.
if i change address of ADSL router to 10.0.3.222 i can connect with vlan 3 but not with vlan 1 and 2.
my config in 851w router:
ip subnet-zero
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 10.0.2.1
ip dhcp excluded-address 10.0.3.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool sdm-pool1
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
ip dhcp pool sdm-pool2
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
ip dhcp pool sdm-pool3
network 10.0.3.0 255.255.255.0
default-router 10.0.3.1
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name boomerangpharma.com
bridge irb
interface FastEthernet0
no cdp enable
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Dot11Radio0
description Cisco Open
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
no ip route-cache
broadcast-key vlan 3 change 10
broadcast-key vlan 2 change 10
encryption vlan 3 key 1 size 40bit 0 1234567890 transmit-key
encryption vlan 3 mode wep mandatory
ssid atmdata
vlan 1
authentication open
ssid atmvlan2
vlan 2
authentication open
ssid atmvlan3
vlan 3
authentication open
authentication network-eap eap_methods
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
channel 2462
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
no cdp enable
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Vlan1
description intvlan1
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description intbvI1
ip address 10.0.0.1 255.255.255.0
ip virtual-reassembly
interface BVI2
ip address 10.0.2.1 255.255.255.0
interface BVI3
ip address 10.0.3.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.222
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 3 protocol ieee
bridge 3 route ip
irisrios
Level 6
Level 6
Have only one BVI and assign it the address 10.10.10.1 as we are tagging the traffic and sending it out to the switch via a dot1q
trunked interface.
dancampb
Level 7
Level 7
You config is fine. Unlike an IOS AP you will need multiple BVI interfaces because you are basically setting up transparent bridging within the router.
The issue is that you are going to need to setup NAT. The DSL router won't have routes back to all of the subnets. That's why when you change the address on it you can get to the Internet for the SSID associated to that subnet.
What I would suggest is connect the DSL router to fa4 and put an IP address on it that matches the DSL router. This subnet should be different than the BVI interface addresses. Then setup NAT so all of the BVI interfaces are NATed to the address you assigned to the fa4 interface.
This way the DSL router sees all of the traffic coming from the router as being from the same source address and would have a route back to it.
