I cant see LAP on the controller however i can ping it from LAP
Ahmed Ayaad
Dear Ahmed,
i have controller with ip :192.168.85.3, when LAP associate with it i see the below error knowing that i can ping the controller from LAP and cant ping LAP from Controller. Also the multilayer  switch can ping controller and LAP
Also the LAP ping on old controller with 192.168.201.10 not found now what is the problem and how to solve it (AP 1130)
*Dec  4 19:37:26.759: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec  4 19:37:27.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.85.3 peer_port: 5246
*Dec  4 19:37:28.387: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.85.3 peer_port: 5246
*Dec  4 19:37:28.389: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.85.3% Be sure to ask the CA administrator to revoke your certificates.
No enrollment sessions are currently active.
*Dec  4 19:37:28.431: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Dec  4 19:37:28.431: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Dec  4 19:37:28.432: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Dec  4 19:37:28.432: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 192.168.85.3
*Dec  4 19:37:29.268: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.85.3
*Dec  4 19:37:29.268: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.85.3:5246
*Dec  4 19:37:29.334: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Dec  4 19:37:29.334: bsnInitRcbSlot: slot 1 has NO radio
*Dec  4 19:37:29.358: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Dec  4 19:37:29.416: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  4 19:37:29.417: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec  4 19:37:29.422: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec  4 19:37:30.357: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec  4 19:37:30.447: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  4 19:37:30.452: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec  4 19:37:30.457: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec  4 19:37:31.482: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  4 19:37:32.482: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Ahmed
Leo Laohoo
Please post the following output:
1. WLC: sh sysinfo;
2. AP: sh version; and
3. AP: sh ip interface brief
Sent from Cisco Technical Support Nintendo App
Hi Ahmed,
Have you configured any AP policies on your WLC? If so you need to add AP MAC to the list.
"show auth-list" output of your WLC shoud provide the necessary information.
Also how does AP get an IP ? Is it DHCP or static ?
Issue "clear capwap private-config" to your AP & then reload it. Post the complete console output of that to further assist
Rasika
**** Pls rate all useful responses ****
HI,
Th AP Get IP from DHCP i create it on MultiLayer switch. already i make "clear capwap private-config" more than one time but the problem still exist.and use option 43 to discover the controller.
I can ping AP and Cotroller from Core switch, AP model 1130
Any way i will post the output shows in above
