Community Member
I have 1100
Hi All,
I have 1100 series access point, where as it my clients are 802.11B. The clients are not detecting this network.
so what are the changes i need APs
Please help me out on this issue
Srikanth
Community Member
Re: I have 1100
none of clients?
Re: I have 1100
Make sure the clients have the correct SSID configured which matches with the AP. Thinking, if its a typo on your side on the client.
Use Express setup and Express security to create an SSID, to which you can readily connect. Once this is done, you can go under security settings to add WEP key or radius authentication.
Community Member
Re: I have 1100
thanks I got solution.
Community Member
Re: I have 1100
hi, how u done ur setting can u provide me a copy of ur setting
i also getting same situation but my side i can let the network scan the wireless for a moment only. later cant detect alr
Community Member
Re: I have 1100
Hi, i have the same situation where i have 3com USB wireless client (54Mbs 11g). I have configured my 1100 AP with SSID and enable broadcasting. but i can't see this wireless network.
Please help!
Community Member
Re: I have 1100
can u send me the config.
Community Member
Re: I have 1100
Here is my config:
Community Member
Re: I have 1100
It seems these access points 1100 rn 802.11b clients only and you need to upgrade in order for 802.11g cliens associate with these Access Points. But i need to know IOS upgrade or what?
Community Member
Re: I have 1100
where is ur attachment
131
