02-01-2012 02:09 PM - edited 07-03-2021 09:29 PM
I have several AP in H-REAP mode, one of them is in a remote location anthe other are in the central location. I want to use the same SSID in both locations with differents VLANS.
In the central site, i have 3 WLANS (SSID) whit 3 different VLAN eachother. I put the local swicthing in one SSID that I want to use in the remote site. In the remote location the users can authenticate and everything works fine but in the central location that SSID doesnt work, the user in the central location can not authenticate.
It seems that i can not use the same WLAN (SSID) and use it en both locations checking the local switching.
What can i do?
Many thanks for your help
02-01-2012 02:20 PM
this should work, and is standard for HREAP deployments.
What authentication are you doing?
Steve
02-02-2012 06:44 AM
Look I have 2 two VLANs Interfaces (vlan 252 & Vlan253) created on WLC, beside the management VLAN (ID 254), and there are 8 AP´s installed at the central location, each AP has been connected to my CORE Switch through switch ports mode Access vlan 254.
th aeuthentitcation i have been used is "LOCAL: WPA-WPA2-PSK" in both locations (Central and remote). In the remote sites, tha AP is connected to a cisco switch through switch port mode trunk, and I use VLAN 251. When the local switching feature is activeted on WLC, I can map the VLAN 251 (in te remote site) to the SSID I am using inthe central site and everything works fine but in the central locations the user can associste to he AP but they can not receive IP from the appropiate VLAN.
I don t know what parameter have to change....
Can you helpme?
02-02-2012 06:45 AM
Can you helpme?
