Community Member
Indoor coverage with outdoor equipment
Sr, I need to provide coverage in all apartments in a building of four floors. I can't install indoor Access Point because bureaucratic subjects. I need provide this coverage using outdoor equipment.
Somebody already made something similar.
thanks !
Re: Indoor coverage with outdoor equipment
Do you mean using outdoor access points indoor or covering indoor from the outside?
In the first case (using outdoor access points indoor) I saw in done in a shopping mall, ti does work properly, even if site survey is a bit of an issue (You need higher mounting for the APs and the amplifier creates coverage patterns and reflections issues a bit specific).
In the second case (covering indoor from access points placed outside), it is more challenging. The penetration power of a wireless wave is not great, you would probably cover well through the windows but have a lot more difficulties through the external walls... depends of course on the building, but I would be cautious...
Jerome
Community Member
thanks Jerome,
My case is the second case. I intend use 1510 Access Points. I will make a site survey to validate this.
Claudio
Good luck Claudio then!
Everytime I tried I had disapointing results, coverage was fine at the edge of the buildings and poor inside...
144
