Installation of .pfx cert on a AIR-WLC2125-K9 controller
I have a client that needs to update a certificate on their 2125 controller. They have created a .pfx cert that does not work because of file type. I wanted to see what the best pratice would be for me to follow installing this cert and do I need any additional cert like a CA. I found a document but am not so sure that it is exactly what I need. Any advice on this would be greatly appreciated.
AIR-WLC2125-K9 : JMX1248K0EL
System Information
Manufacturer's  Name.............................. Cisco Systems Inc.
Product  Name..................................... Cisco Controller
Product  Version.................................. 6.0.188.0
RTOS  Version..................................... 6.0.188.0
Bootloader  Version............................... 4.0.191.0
Emergency Image  Version.......................... N/A
Build  Type....................................... DATA + WPS
Re: Installation of .pfx cert on a AIR-WLC2125-K9 controller
the following link shows you what needs to be done to generate a certificate for the WLC.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a77592.shtml
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
HI Steve,
I went through this process and try the tftp and it fails. I can see the trasfer go in the log but it will not install. There is an old cert in there already but thats it. Any ideas. the device fails to install cert..
508
