Intel 5300agn and 1232g access point
Hi all,
I am having some issues connecting an Intel 5300agn nic to our Wireless G access points with WPA2+Peap.
Can the 5300 connect to 2.4ghz G or is it built mainly for 2.4 N on the 1250N ap, which it can happily connect to.
Thanks.
1 REPLY
Re: Intel 5300agn and 1232g access point
What issues specifically... ? Can you connect at all?
I have the 5300 agn's, in fact we have a bunch of them.... Try unwrapping the security from the ssid and see if you can connect and then start reapplying it ...
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
229
