Interface Dot11Radio0, Deauthenticating Station Reason: Sending station has left the BSS
Dear сolleagues,
I have a problem with two AP AIR-AP1262N-A-K9:
Interface Dot11Radio0, Deauthenticating Station xxxx.xxxx.xxxx Reason: Sending station has left the BSS
Both access points are powered by PoE.
Product/Model Number:AIR-AP1262N-A-K9
Top Assembly Serial Number:FGL1615S2AC
System Software Filename:ap3g1-k9w7-tar.124-25d.JA1
System Software Version:12.4(25d)JA1
Bootloader Version:12.4(23c)JA
System Uptime:23 hours, 4 minutes
Configuration of AP:
TMAGLAP01#sh run
Building configuration...
Current configuration : 4383 bytes
version 12.4
no service pad
service password-encryption
hostname TMAGLAP01
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone +0500 5
dot11 syslog
dot11 ssid BAB_Guest
   vlan 120
   authentication open
   authentication key-management wpa
   mbssid guest-mode dtim-period 1
   wpa-psk ascii 7 045C1E031C351D1C5A
   information-element ssidl wps
dot11 ssid BAB_Staff
   vlan 121
   authentication open
   wpa-psk ascii 7 0612077042451E105012
power inline negotiation prestandard source
username maxim.s privilege 15 password 7 03095A130F02701E1D5D
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 121 mode ciphers aes-ccm tkip
encryption vlan 120 mode ciphers aes-ccm tkip
broadcast-key vlan 121 change 10000
broadcast-key vlan 120 change 10000
broadcast-key change 10000
ssid BAB_Guest
ssid BAB_Staff
antenna gain 128
mbssid
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2.
m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
packet retries 128 drop-packet
channel 2422
station-role root
rts threshold 512
rts retries 128
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.120
encapsulation dot1Q 120
no ip route-cache
bridge-group 120
bridge-group 120 subscriber-loop-control
bridge-group 120 block-unknown-source
no bridge-group 120 source-learning
no bridge-group 120 unicast-flooding
bridge-group 120 spanning-disabled
interface Dot11Radio0.121
encapsulation dot1Q 121
no ip route-cache
bridge-group 121
bridge-group 121 subscriber-loop-control
bridge-group 121 block-unknown-source
no bridge-group 121 source-learning
no bridge-group 121 unicast-flooding
bridge-group 121 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid BAB_Guest
ssid BAB_Staff
antenna gain 0
dfs band 3 block
mbssid
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.120
no ip route-cache
bridge-group 120
interface Dot11Radio1.121
no ip route-cache
bridge-group 121
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.120
no ip route-cache
bridge-group 120
interface GigabitEthernet0.121
no ip route-cache
bridge-group 121
interface BVI1
ip address 10.40.253.42 255.255.255.0
no ip route-cache
ip default-gateway 10.40.253.254
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
terminal-type ansi
line vty 0 4
terminal-type ansi
end
What could be the real reason?
  • Other Wireless - Mobility Subjects
1 ACCEPTED SOLUTION
VIP Purple
Re: Interface Dot11Radio0, Deauthenticating Station Reason: Send
HI Maxim,
Make sure that if your using WPA and not WPA version 2, that your only using TKIP. When using WPA2 then you would use AES.
Use only :
encryption mode ciphers tkip
If still fails then:
you must check the client drivers as that might also be the cause, its most likely a client issue
Dont forget to rate helpful posts.
VIP Purple
Are you having this issue only on radio 0 (2.4GHz clients) ?
When client get disconnect, are they within the proper coverage area ?
You may try below & see if that helps
int d0
channel least-congested
Rasika
**** Pls rate all useful response ****
VIP Purple
HI Maxim,
Use only :
Dear Sandeepchoudhary21,
We are using WPA2.
What's a problem with the client's drivers yet?
Until Сisko we have a simple access point D-Link, and never had any problems.
VIP Purple
Hi Maxim,
But as per your config: authentication key-management wpa
You are using only WPA then u must use TKIP.
https://supportforums.cisco.com/docs/DOC-14496
Its alwayes good to use WPA2 with AES and WPA/TKIP, sont use mix of these.
If you are using WPA2 then use : encryption vlan 120 mode ciphers aes-ccm
If WPA/Tkip then: encryption vlan 120 mode ciphers tkip
May the client drivers are not up to date. Please update them and then try again.
Dear All,i get the same issue
Dear All,
i get the same issue and after change setting as you mentioned but the problems still exist.
Interface Dot11Radio0, Deauthenticating Station a088.b40f.c6fc Reason: Sending station has left the BSS
Best Regards,
Saroth
2884
