Intermittent Connectivity after Implementing WEP
I am using an AIR-PCM352 to connect to a 350 series AP that is running 12.03T
Everything appears to operate normally until I implement 128bit WEP on the AP, with open authentication and no broadcast SSID. AT that point, my card loses association with the AP approximately every 3 to 5 minutes. It doesn't matter what signal strength, location, direction, or any other physical factors are involved, the problem is the same.
my NIC has firmware 5.20.17 and I am running ACU 6.1.002
Engineers in the same room do not have any problems with using integrated NICs from their Toshiba laptops.
Re: Intermittent Connectivity after Implementing WEP
What NDIS driver version for the client card ??
NDIS is V8.3.10
NDIS is V8.3.10 - I am still looking for resolution on this problem. I am updating it, hoping that someone might notice it.
Thanks!
116
